MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
Old 12-10-2004, 12:55 PM
scyzoryk's Avatar
I thought that maybe someone will be happy to see this. We waited so long for something like this(but not for ($500) and here we have...
OPTI
Sebastian
scyzoryk is offline
Old 12-10-2004, 01:12 PM
Evil Eric's Avatar
Re: MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
I have sen those and the only thing i dont like is that its not the whole opti unit, just the cap and rotor. i do however think that is cheaper than the estimate that they gave me on a stock replacement cap and rotor at advance.
Evil Eric is offline
Old 12-10-2004, 01:39 PM
SVWHAT's Avatar
It has been awhile since I changed mine. What else do you need. I was thinking everything else inside you could reuse. I really can't see why they would sell this piece if you still needed other parts. BTW its only $151.99.
SVWHAT is offline
Old 12-10-2004, 02:32 PM
The Opti has 2 "halves" - BOTH of them can fail. The front section is the cap and rotor. The back section is the housing, including the bearing (low quality, wears out), the optical sensor and rotating "disc", and the seal for the harness connector, which is the primary "leakage" source. The cap/rotor represents the bulk of the failures, but in maybe 20-25% of the cases, the optical sensor gets crudded up with rust from the cheap carbon steel bearing retainer plate, or the bearing wears out. Replacing only the cap/rotor on a high mileage Opti is risky.
Injuneer is offline
Old 12-10-2004, 02:53 PM
Advanced Tech Moderator
kmook's Avatar
http://web.camaross.com/forums/showthread.php?t=315840
And as said it's just the cap and rotor...
kmook is offline
Old 12-10-2004, 02:56 PM
Super Moderator
95 Z/28 LT1's Avatar
JMO, but I doubt it's much better than the stock one.
95 Z/28 LT1 is offline
Old 12-10-2004, 08:19 PM
OPTI
Sebastian
Your kind of late to the party. This has been posted by numerous people for several weeks, now.
I don't see where a cap and rotor is much to get excited about.
shoebox is offline
Old 01-28-2005, 10:02 PM
DavesLT1's Avatar
just wondering if anyone has tried this yet. and if so, how did it work?
DavesLT1 is offline
Old 01-28-2005, 10:11 PM
turbo_Z's Avatar
It looks like they improved the rotor tip design with a plastic retainer and solid metal rivot. That IMO was the weakest link in the opti.
I may buy one next month to check out but I probably wont be installing it since my opti is only a couple months old.
turbo_Z is offline
Old 01-28-2005, 10:31 PM
DavesLT1's Avatar
I might get one and replace my opti at the same time just to be sure as I have no clue as to how old my opti is, and my car has 78k on it.
DavesLT1 is offline
94Z28LS1toLT1
01-10-2015 10:27 AM
ScottZ
03-03-2004 01:34 PM
carcrazyQT
09-17-2002 07:54 AM
carcrazyQT
09-03-2002 02:51 PM
smackkk
07-22-2002 05:17 PM
Quick Reply: MSD Ignition LT1 Distributor Cap and Rotor Kits (OPTI)
