Motor mounts
Old 04-16-2015, 07:23 AM
KYWes's Avatar
Motor mounts
'95 Z28
Asking for your experience and suggestions regarding replacing the motor mounts on these cars.
Are they known to collapse, compress, etc?
I have 125,000 miles on the car and mine look good. I don't want to go to performance mounts but rather stay with factory.
KYWes is offline
Old 04-16-2015, 03:30 PM
timnfxr's Avatar
Re: Motor mounts
The mounts longevity depends a lot on how the car is driven, maintained, or abused. If yours look good, I'd say there's no need to replace them. Just inspect them during maintenance cycles.
If your car has been cared for, they should still have a lot of life left in them with 125k. Mine are still originals at 225k and still in good shape.
timnfxr is offline
Old 04-17-2015, 07:52 AM
KYWes's Avatar
Re: Motor mounts
Thanks man, you confirmed what I was thinking.
KYWes is offline
Old 04-20-2015, 08:02 AM
Strick's Avatar
Re: Motor mounts
Most guys say to stay away from poly or stiffer mounts, except for racing only. Otherwise the ride will be too harsh.
Strick is offline
Old 04-20-2015, 08:12 AM
KYWes's Avatar
Re: Motor mounts
Yeah, that's what I was thinking Strick. I'm looking for a spirited, comfortable ride not racing or being beat to death. Thanks for the post.
KYWes is offline
Old 04-22-2015, 01:26 PM
maybe2fast's Avatar
Re: Motor mounts
I have poly mounts...don't notice anything abnormal about them...
maybe2fast is offline
Old 04-22-2015, 04:08 PM
Re: Motor mounts
I wouldn't think poly motor mounts would cause a "harsh ride".... just a bit more vibration transmitted from the engine.
Injuneer is online now
Old 05-03-2015, 08:51 AM
maybe2fast's Avatar
Re: Motor mounts
I almost feel like they are a must with headers. The y-pipe always was so close to the floor and would hit the floor (I know mine were worn) but even before they were bad it was iffy. Now the y-pipe is in the place and doesnt move.
Old 05-03-2015, 09:37 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Motor mounts
Simply looking at them may not be enough. Make sure they haven't separated from the metal brackets using a small pry bar or large screwdriver. My LS1 trans mount looked perfectly normal until I tried to lift the transmission and saw it separate. The motor mounts looked ok but had sagged just enough for the metal hidden by the rubber to have bottomed out on the mounting plate.
GaryDoug is offline
Old 05-04-2015, 06:15 AM
Strick's Avatar
Re: Motor mounts
Just something to think about....When these Camaros were built back in Van Ness,Ca, the quality control was not the best. Some of the frames and unibodies were not exactly the same, measurement wise, once completed. That is why some guys have no problems with some fitment issues and some others do have problems. Now put 20 plus years on these cars and the designed measurements are likely to be even further out of spec. Like I say, just something to think about.
Strick is offline
Old 05-04-2015, 08:39 AM
Re: Motor mounts
All 4th Gens were built in St. Therese, Canada.
Old 05-04-2015, 08:54 AM
Strick's Avatar
Re: Motor mounts
My mistake, I was thinking 3rd gen, but the basic idea still applies.
Strick is offline
Old 05-06-2015, 04:21 AM
KYWes's Avatar
Re: Motor mounts
Good ideas and suggestions. Thanks.
KYWes is offline
Old 05-06-2015, 11:30 PM
Fatdog2's Avatar
Re: Motor mounts
Might check out a local chevy dealer for mounts.I just picked up a new trans mount for $23. brand new.Was I surprised.
Fatdog2 is offline
Old 05-07-2015, 08:12 AM
Prominent Member
GaryDoug's Avatar
Re: Motor mounts
Motor mounts aren't discontinued yet. GM still makes/sells them.
GaryDoug is offline
HectorM52
07-30-2017 11:46 AM
Rde Bandit
03-21-2015 10:17 PM
DirtyDaveW
03-15-2015 07:01 PM
silvermansteve
03-04-2015 05:02 PM
Nostang 96z
08-31-2002 12:01 PM
Quick Reply: Motor mounts
