leaking water pump
leaking water pump
Maybe someone has done this before, not for sure though. I was thinking the other day how to fix the dreaded waterpump leak. I found if you get a 3/16 tap in grease fitting and drill out the inside of it so you can see though it and tap it into the pump weep hole and get about 1 1/2 feet of heater hose and connect it to the grease fitting. It will go past the opti and wont get it wet next time it goes out. As for if the gasket goes out I don't think there is much you can do for that..... Anyone done this before??
Re: leaking water pump
thx
Magenta_Hearts
03-29-2017 08:54 PM
Blood type Z28
04-08-2015 11:34 PM
