Front Wheel Bearing and ABS
Old 12-30-2003, 07:38 AM
athens96ta's Avatar
The driver's side front wheel bearing is goig bad on my TA. Will this trigger the ABS inop light?
Thanks,
Loren
athens96ta is offline
Old 12-30-2003, 08:05 AM
1fast95Z's Avatar
No, the bearing going bad should not affect the abs system.
1fast95Z is offline
Old 12-30-2003, 03:01 PM
PGR
PGR's Avatar
If the wheel bearing is REALLY loose, it can trigger the ABS inop light. The ABS sensor and relector ring are integrated into the wheel bearing assy, so a really loose bearing will create an inconsistant reluctor gap, which can trigger the abs sensor.
Jack up the front of the car, and try to rock the wheel back and forth (grab it at the 12 and 6 o'clock position). There should be no play. If its more than a quarter inch of play, I would suspect it's triggering the ABS inop.
PGR is offline
10-31-2016 11:09 AM
jj_burchiel
03-21-2015 12:51 AM
warmeck
03-08-2015 08:01 PM
Doug Harden
29
07-30-2003 07:05 AM
z28projects4ever
133
07-26-2002 01:54 AM
Quick Reply: Front Wheel Bearing and ABS
