Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
Yes you will need a disconnect tool.
Disconnect both lines and unbolt the fuel rails, disconnect the electrical connections to the fuel injectors. Pull the vacuum line off the regulator. Pull the rails off making sure O rings come out still attached to the injectors.
You will need a star socket to remove the FPR from the rails....not sure what size, I just use the one that fits .....and its pretty straight forward once you can get a good look at it.
Installation is the reverse of removal.......Don,t you love when the manual says that?
you dont have to remove the fuel lines. you can just unbolt the fuel rail and there should be enough slack to where you can turn the rails upside down and get to the fpr. one thing you might want to do when putting everything back together, is add a small amount of oil to the o-rings so everything will go together easier.
I've replaced the FPR without disconnecting the line(s), and without pulling the rails. There is a single T27 Torx screw that holds it on. You do have to release the clamp that holds the two hardlines to the bracket on the end of the intake manifold.
Relieve the pressure in the lines by depressing the core of the Schrader valve (keep a rag around it, preferably when engine is cool). Unhook the vacuum compensation line. Release the bracket that holds the hard lines. Pull the clip that holds the hardline to the FPR and pull the line out of the FPR. Put a rag under the FPR..... fuel will still drain out of the rail. Unscrew the T27 screw. Gently twist the FPR until it pops out of the rail. Make sure you didn't lose any o-rings.
94 Formula A3+1: 381ci all-forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons/CNC LT4 heads/Comp Cams custom solid roller/TH400+GearVendors OD/4.11's/Strange 12-bolt/300-shot N2O/Spohn Suspension/6-pt roll bar with integrated SFC's/full AutoMeter instrumentation/MoTeC M48 Pro engine management system/a few other odds 'n ends.
My website is down. Hopefully, links/photos be restored in 2 or 3 weeks.
I think I'll be doing it with the rail on the car. I do have a torx for that and am fairly used to tight spaces on this car This should be a walk in the park lol.
__________________
1995 Black Z28 Vert A4: 1LE Intake Elbow, K&N CAI w/ AMSOIL conical filter, TB Bypass, !AIR, LT4 KM, Magnaflow Catback, 30# Injectors, Revalved Bilsteins, Hotchkis Springs, Addco Adjustable PHB, Rebuild@166k. Opti, !CAT, 35mm Strano Swaybar, Transgo, Yank 3200 Stall, MAC mids, Poly Ball Tubular LCA's, Relocation Brackets, UMI Chrome Moly STB
Ok need a bit more help here (I think)
I tried to do the swap today, everything was going fine until the T27 I thought i had it in my set but it apparently jumps from T25-T30. Anyhow, so i couldnt get that off (picked a T27 later that day).
The clip seems a bit tricky to get off. Any tips for how to remove it? I only tried by hand, mainly because I'm afraid of flinging it off somewhere in the engine.
Also, after hte clips off, do I unscrew anything after that? Will i need a special wrench, or is it doable by hand..
Doing this all with the rails still in, it seems easy enough to access once i get the things off.
Thanks for all the help so far
__________________
Do you mean the little square spring clip that holds the hard line in the regulator? That should just pull off with a pick or a small pliers. Its not going to go flying off, but you run the risk of dropping it.
Once the spring clip is off, and you've released the hard line from the "t" bracket that holds the two lines, the line can be pulled gently out of the FPR. I think there is supposed to be an o-ring on the end of the hard line.
The "t" bracket is a bit of a PITA too, because the screw head (another Torx) is facing down toward the intake manifold. But its "doable".
Well finally got it in. Wasn't a lot of fun either LOL.
Anyhow, I managed to get the T27 in the back off easily enough (was REALLY tight in there though). But the bracket holding hte hard lines had a T25 torx in it and it was a total pain the ****!. I have some electrical component right below that torx bolt so I couldnt fit my socket in there, not enough clearance for the head.
I lifted the rail up and out a few inches just so i could get the socket in there. Finally was able to get it out. There was an O-Ring on the hard line to the FPR which I was careful to keep on.
Anyhow, I would recommend looking at the bracket that holds the hard lines in FIRST before you decide which way to tackle it. If it looks like you can fit a socket and torx down there, great. If you can't i would highly recommend pulling the rails first.
Thanks for the help everyone
__________________
