FLP lt's - what gasket??
Old 03-24-2003, 03:53 PM
playaz28's Avatar
what kind of header gasket would be best to go with?
right now the setup i had was **don't know what kind of gasket** but it was fiberous, with stage 8 bolts (3 of which backed out??), lt4 hc kit, ported stock heads, k&n cai...
also would stage 8 be good to go with or does it really matter? arp's 12 point hex stainless??
playaz28 is offline
Old 03-24-2003, 03:59 PM
EviLBoX's Avatar
I'm using Fel-Pro gaskets with my FLP's and they've worked out great. I haven't had any leaks since I put them in over a year ago.
EviLBoX is offline
Old 03-24-2003, 04:29 PM
1BadBrd's Avatar
Used felpro also and works good. Fits good, no problem. Just installed the headers last week and you will love the difference
1BadBrd is offline
Old 03-24-2003, 04:31 PM
KenP's Avatar
I also use Felpro, #1406. I also use standard header bolts and have been leak free for 2 years. Just remember to tighten them down after a few heat cycles. After that, I check them at least once a month. I also put antiseize on all bolts before installation.
KenP is offline
Old 03-24-2003, 05:52 PM
playaz28's Avatar
thanks all.
playaz28 is offline
magman
04-15-2016 03:08 AM
93 RedBird
11-15-2015 08:24 AM
IndyZman
10-22-2015 02:17 PM
WobblySausage
10-07-2015 02:44 PM
pepon214tx
09-20-2015 04:48 PM
Quick Reply: FLP lt's - what gasket??
