How to cheat emmissions 101! It worked!
#31
No Emission Testing Here
Originally posted by SSlammedlt-4
Im glad we dont have emission tests here in the heart of America. I love running no cats and no egr. it great, not having to worry if I am going to pass the mext test.
L8
Shawn
L8
Shawn
#32
cool man.u know what sucks about where i live is that the county that is 10 min down the street from me DOESNT have e-check and mine does. go figure. stupid state funding thng is all it is.mabey they should start testing semis and things that blow black smoke from their stacks, the real auto polllutants!!!!!
#33
thats not correct. diesel smog is just particulate matter, just floats around and then settles on the ground, just like dust or something. sure it might not be good for the lungs if u inhale allot of it, but gas fumes is what kills the ozone. thats why diesels have not had smog tests up untill recently.
#34
#36
Re: How to cheat emmissions 101! It worked!
Originally Posted by Johnnynsac
Now what would happen if you were to get caught? hmm
#37
Im with djlup..I'm curious as to what 2 injectors and EXACLTY what was invovled..step by step that you did to pass it..I have to get my Z emissioned soon and I have an aftermarket cam and all that stuff upgraded, only thing stock is my exhaust manifolds really..even the exhaust and cat are 3". So with my mods in my sig..will I have a problem?
My first impression was that the car would hesitate and not run right if you disconnected even 1 injector
All in all..the injector thing is WAY better than the AIR trick IMHO...if all you do is disconnect something..then put it back to normal..you're set and nothing got messed up. The other way requires drilling and welding and all that crap. Someone tried this that can make a 'how to' list?
#38
Originally Posted by BlackLT1_TX
i can only imagine, i live in dfw, rolling smog test every year, and random emissions testing units on random offramps ready to sniff you as you drive over them, if you are above the limit it snaps a photo and then you find a notice that you have to get your car reinspected within so many days or something. it sucks, made me put my cat back on
if i get a cam or headers i'll pull it off, just wasnt enough hp to run without it.
* BlackLT1_TX, I can feel your pain since I live in Sacramento CA. We have the same emissions testing with the exception of everyother year. Next time you know where they are measuring drive-by emissions, turn your engine off in the measurement area. That will be measured as an error. Enough errors and they don't send the violations and they have to check the equipment for proper calibration. Really it works if enough people do it.
* Do you have to make any adjustments (whatever) if you remove your cat?
#39
Originally Posted by tomatocity
* Are there O2 sensors before and after the cat? ....
