Changed oil before storage, change again before startup in spring?
I changed the Mobil 1 oil in my Z before I put it into storage last fall. Do you think I should change the oil again before I start it up this spring or just change it at my next 2,500 mile interval?
Jeff
Jeff
I wouldn't change the oil again, however what I do after winter storage is pull the coil wire (or fuse for fuel pump to keep it from firing) and crank it for a while to get some oil circulating before starting.
Lt1son
12-31-2014 01:35 PM
07-04-2005 05:00 PM
