Belt Squeek Only When Shifting
Old 06-23-2012, 08:47 PM
TobyZ28's Avatar
Having a momentary squeek (< 1/2 a second) at WOT (moreso when downshifting or releasing throttle very rapitly after WOT) coming from the belt/pullys. This is one of Frank C's A4's w/ a 3200 Stall.
Belt is dead silent at all other times. I've replaced the tensioner not too long ago, and the belt's definatly not that old either.
Q1: Is this anything to be concerned with?
I have a gatorback kicking around in the garage, but i'm just wondering if this is something others have just learnt to live with on stronger shifting A4's
Q2: The car shifts HARD into 2nd, even with mid throttle. I recall on older rebuilt tran's this went away over time... So far its still shifting hard - is this a good thing or something to be concerned with?
TobyZ28 is offline
Old 06-23-2012, 11:13 PM
Re: Belt Squeek Only When Shifting
Never had another shift squeak after installing a Gatorback.
shoebox is offline
Old 06-24-2012, 12:19 AM
jloshotz's Avatar
Sorry to hijack, Rob, do you know the part # for the gatorback that fits the LT1 with stock accessory configuration?
jloshotz is offline
Old 06-24-2012, 09:26 AM
moparman's Avatar
The Gatorback belt puts the kibosh on belt squeak.
moparman is offline
Old 06-24-2012, 11:24 AM
It depends on the year. There were two different belt sizes used, due to a change in the a/c pulley size.
My 95 used this one, but earlier years might use a 637 instead of a 642:
shoebox is offline
Old 06-24-2012, 11:34 AM
jloshotz's Avatar
Thanks Rob, mine's a 95 as well
jloshotz is offline
Old 06-25-2012, 04:00 PM
2QUIK6's Avatar
Mine squeels as well, didn't know there was a fix besides putting on fresh belts very often! Thanks for the info!
2QUIK6 is offline
Old 06-26-2012, 11:01 AM
TobyZ28's Avatar
Thanks for the reply's i'll my gatorback on then and see how it goes
TobyZ28 is offline
Greg88
08-24-2015 07:59 AM
War Engine
08-21-2015 05:28 AM
john henry
08-14-2015 08:33 AM
john henry
Classic Engine Tech
08-14-2015 08:33 AM
Cam's maro
08-11-2015 07:45 AM
Quick Reply: Belt Squeek Only When Shifting
