94 z28 water pump & opti ? help :/
Old 09-25-2015, 05:39 PM
colts0455's Avatar
ok well my cars locked out till get new key my vats will not let me into my car. my water pump is starting to show signs of leaking so its getting changed my ? is do i need to do the opti while im doing the water pump & also do i need to replace Water Pump drive shaft seal ? & optispark seal ? or will they be fine. just feel like cant get ahead on this car :/
colts0455 is offline
Old 09-25-2015, 08:53 PM
Re: 94 z28 water pump & opti ? help :/
It depends on whether you are having issues with those things.
shoebox is offline
Old 09-25-2015, 09:36 PM
colts0455's Avatar
ill shoot & say opti is fine even tho im sure is from 94 & no idea about seals but i do know the water pump is leaking.
Old 09-26-2015, 10:12 PM
colts0455's Avatar
so how can i tell if seals need to be done ? its got 146miles pretty sure water pump is stock & opti & seals
Old 09-27-2015, 11:31 AM
You simply look for evidence of any leaks.
shoebox is offline
Old 09-27-2015, 01:07 PM
colts0455's Avatar
ok i think im just doing the pump weather just been so bad here in NC. gotta wait on my key my vats locks me out cant crank my car :/
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
94Z28LS1toLT1
01-15-2015 07:18 PM
pologreen97z
12-02-2014 10:42 AM
thenewkid
11-27-2014 09:41 AM
Quick Reply: 94 z28 water pump & opti ? help :/
