383 Stroker .030 over is 6.3liter, so what's a...
Old 10-15-2003, 08:59 AM
zhevy-1's Avatar
383 bored .040 over ?
What's the new CID and liters?
Thx-Goose
zhevy-1 is offline
Old 10-15-2003, 09:01 AM
95 Silver TA's Avatar
I believe a .40 over bore with a 3.75 stroke would be 385 Cubic Inches.
Thx,
Claude
95 Silver TA is offline
Old 10-15-2003, 09:07 AM
zhevy-1's Avatar
It has 6" rods, if that helps.
zhevy-1 is offline
Old 10-15-2003, 09:16 AM
The longer rod will not effect Cubic Inches but will give more torque..You will still end up with 385 CI with a .040 overbore and a 3.75 inch crank.
Thx,
Claude
Old 10-15-2003, 09:22 AM
gb95zconv's Avatar
Simple ratio will give you the answer....solve for x......Im not gonna do all the work for ya
5.7\350 = x\385
gb95zconv is offline
Old 10-15-2003, 09:34 AM
zhevy-1's Avatar
5.7\350 = x\385
Cool, man. That should help.
zhevy-1 is offline
Old 10-15-2003, 10:19 AM
supermo26's Avatar
Thoes teachers were right, Math is inportant.
supermo26 is offline
Old 10-15-2003, 05:34 PM
OldSStroker's Avatar
Originally posted by Slow95car
bore * bore * stroke * 8 * .7854
.061cid = 1 cc = 1ml
Yep. Everything you need to know.
Sometimes using 61 cu.in. = 1 Liter is convenient.
Example: 4.04 * 4.04 * 8 * .7854 = 384.57 cu. in.
384.57 cu. in /61 = 6.30 L
OldSStroker is offline
Old 10-15-2003, 05:51 PM
On permanent vacation
TreySpeed's Avatar
just to clarify, by bore im' sure he means radius
area of circle times length or depth :0
4.04'' = diamter
2.2'' = radiuis
area = pi R^2
so 3.14 *2.02
multiply by stroke
so 3.14 *2.02 *3.75
multiply by number of clyinders
3.14 *2.02* 3.73 * 8
TADA!
TreySpeed is offline
Old 10-15-2003, 05:57 PM
94formulabz's Avatar
I don't think so, .7854 is Pi/4.
Your formula is also correct though
94formulabz is offline
Old 10-15-2003, 06:10 PM
TreySpeed's Avatar
woops, made the mistake of just spotting the bore *bore and assuming it meant radius ^2
I didn't realize you went through all the trouble of simplifying
I was never one for memorizing that stuff. i just memorize fundimentals and derive from there.
I cant believe the way people memorize trig identites
Sin^2 + cos^2 = 1 will get you them all; how people havn't noticed this is beyond me
Old 10-15-2003, 06:22 PM
95 z28 noob's Avatar
I'm thinking I shouldn't have cut math class so much now!
95 z28 noob is offline
Old 10-16-2003, 12:57 PM
Z28SORR's Avatar
How can Oldsstroker, miss the stroke. Your one number short!
Or, D^2 * h * N * .7854 = X cu. in. /61.024 = X liters
Are we having fun yet!!!
Z28SORR is offline
Old 10-16-2003, 02:12 PM
dynomight's Avatar
so what is the answer?
dynomight is offline
Quickss96
01-29-2016 05:56 PM
Z Power
09-19-2015 11:19 PM
cristian1311
09-12-2015 08:16 PM
95craz28
11
09-12-2015 07:47 AM
alphaauto
07-26-2015 04:40 PM
Quick Reply: 383 Stroker .030 over is 6.3liter, so what's a...
