2000 s10 with lt1 motor backfiring
lt1 motor in 2000 s10 backfiring
I have a 2000 s10 with lt1 motor in it that is backfiring. new distributor, plugs, wires, cap and new fuel pump. Injectors are not leaking. Any suggestions as to what is causing it to backfire.
Re: 2000 s10 with lt1 motor backfiring
Backfiring when? Idle, accel, decel? Is the motor modified at all or is it stock? Did it happen after the new opti/cap/plugs/wires? Basically, when did it start backfiring??
Re: lt1 motor in 2000 s10 backfiring
Let's move this to "LT1 Based Engine Tech"..... More likely to get tech help there than you are here in "New Member Introduction".
Have you scanned it for codes? Was it backfiring before you changed out all the parts you list? Have you checked the fuel pressure? Have you checked the valve adjustment? What year is the LT1 engine? What year ECM/PCM are you using? Is the engine stock, or modified? If modified, what has been done?
And, still need this info:
I understand you haven't "messed" with the valve adjustment, but have you checked it?
10-31-2016 11:09 AM
