2000 plastic tank: What pump Kit to buy/racetronix 93 or 99+
I am upgrading to the 99+ plastic gastank and while I'm doing this I am going to upgrade the fuel pump. So far people recommend the Walbro/racetronix setup.
I'm looking at the kits and they have recently upgraded to the new better fit styles.
they have two kits. the LT1 kits and the LS1 kits.
I'm curious about the wireing on the LS1 kits.
Are they the same, do I buy a LT1 Wire harness with a LS1 pump?
Do I need the wireing harness?
I am clueless on this upgrade, any replys greatly appriciated.
thanks
thanks
Re: 2000 plastic tank: What pump Kit to buy/racetronix 93 or 99+
I think the best way to get the answer you want is to email Racetronix. I'm sure they are the most qualified to answer your question.
You would require a custom harness. The fuse holder and interface for the factory wiring (power trigger and level sender) would have to be LT1 based and the fuel module plug would have to be 99+ F-LS1 based.
E-mail sales@racetronix.com for lead times and pricing.
You will need to fabricate some custom plumbing to interface the module to the F-LT1 factory metal lines.
Would it be possible to take the whole module out of a steel tank, and use it in a plastic tank(i.e. take off the five nuts that hold the module onto the steel tank, and drop it into the plastic tank and tighten the five nuts down)?
so basically just changing tanks.....
Deadbolt24
01-19-2015 01:29 PM
squarehead
11-21-2014 08:02 PM
