spinning crank lt1 hub/balancer
Old 03-24-2010, 04:01 AM
95TALT1's Avatar
I have a vortech supercharged lt1 and I keep spinning the hub. With the rebuilt engine and stock hub I spun it one day. It was no longer a press fit so I bought a keyed hub and keyed it. That lasted a little bit and then it sheered the key. It happen two more times and I have now parked it. Is there a kit or solution to fix this. On one episode they put a supercharger on an ls1 and drilled the crank and hub and roll pinned it. I would try to find just that part of the kit but it was for the ls1. Any help would be greatly appreciated.
Thanks,
Waylon
95TALT1 is offline
Old 03-24-2010, 05:18 AM
Sounds like the nose of the crank is worn beyond repair.
For extreme boost with both the Vortech and the Pro-Charger, I've seen people run the ATI Super Damper/keyed hub, with the hub externally reinforced, and dual keys. Without the dual keys and the reinforcement, the hubs simply crack.
Injuneer is offline
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
Brandon Wittmer
12-20-2014 09:51 PM
1LEThumper
07-14-2003 12:45 PM
Hot Rod Hawk
08-30-2002 10:12 PM
Quick Reply: spinning crank lt1 hub/balancer
