1993 Camaro z28 LT1 6 speed
Re: 1993 Camaro z28 LT1 6 speed
May I suggest adding a signature so we know more about your car? Is it bone stock or does it have mods? What's your long term goal for the car? (cam & done? or cam just the start?)
the short answer to what needs to be done is....
build up a nice pot-o-gold for mods!
good luck
good luck
If you are posting from a phone, the "Signature" may not automatically append to the post. If you have that problem, it would be a good idea to start off each new topic with basic into about your car.
I hope you meant to say the cc503, the 305 is more of a blower grind. You'll also need rockers, springs, gaskets, 160 stat and probably an oil pump drive gear minimum. Along with a new timing set and a tune.
mark0006
03-21-2015 12:32 AM
ChrisFrez
02-15-2015 08:12 AM
Aaron92677
05-29-2002 06:08 PM
