Will an LT1 T56 work with an LS1?
Old Jan 17, 2012 | 10:13 AM
93transam1234's Avatar
Getting ready to start my 4l60e - T56 swap on my LT1, but I was think, since i am going through all the work why not put a worked LS1 in there.
I just dont want to go through the trouble of gathering another T56 swap kit.
Old Jan 17, 2012 | 10:15 AM
Marc 85Z28's Avatar
Re: Will an LT1 T56 work with an LS1?
The input shaft is specific to the engine.
Old Jan 17, 2012 | 10:17 AM
DonHood's Avatar
Pretty sure they're the same except for the input shaft and bell housing.
Old Jan 17, 2012 | 10:21 AM
Dyosis's Avatar
They are different. Besides what Mark said, I believe the slave cylinder is mounted on the outside of the bell housing on LT1 T56's and inside on the LS1 T56's. It's a complete PITA to swap out an LS1 slave cylinder.
Old Jan 17, 2012 | 10:39 AM
ok, since i have 0% exp with manual transmissions ill just stick to what i have now.
Old Jan 17, 2012 | 12:44 PM
quickchicken's Avatar
GMHTP (I think) just did an article on this swap so it can be done.
Old Jan 17, 2012 | 02:37 PM
97FormulaWS-6's Avatar
It can be done, requires a new mid-plate, bellhousing, and input shaft. Easier to just pick up a LS1 trans, or get a hold of the place in texas that does T-56 trans and do a trade-in. I believe the pedals will work, but you will need a different MC as well.
Old Jan 17, 2012 | 09:28 PM
SCNGENNFTHGEN's Avatar
Yes they did.
Old Jan 17, 2012 | 11:23 PM
ACE1252's Avatar
For those who do get interested in doing a LS1 conversion on a LT1 T56......
Home of Tranzilla - Rockland Standard Gear, Inc.
Call those guys and ask about part number "LT1/LS1". The kit should come with a LS1 T56 front cover, bearing shims, and LS1 T56 input shaft. The GMHTP article reports that the kit is $398.00.
rideordie
Nov 5, 2019 04:52 PM
ddr698
Jan 9, 2015 10:05 AM
nballisru
Dec 14, 2014 05:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
