No Reverse 2001 SS
Old 06-12-2015, 06:12 AM
Beave2780's Avatar
No Reverse 2001 SS
Switching gears is extremely difficult and yesterday NO reverse. Master slave cylinder was just replaced and fluids are topped off. Happen once before, but the system worked itself out.
Anyone know what could possibly be going on?
Beave2780 is offline
Old 06-12-2015, 10:50 AM
Re: No Reverse 2001 SS
Are you able to get the shift lever all the way to the right, past the reverse lockout, and into the gate? If so, goes the lever simply not move into reverse at all? ...difficult but goes into gear? ....grinds going into gear?
Injuneer is offline
Old 06-12-2015, 01:25 PM
Beave2780's Avatar
You have to force the shifter into place to hit the gears and yes some grinding.
Stock Clutch at 140,000
Old 07-07-2015, 06:36 AM
Super Moderator
JakeRobb's Avatar
Sounds like the clutch isn't disengaging all the way. Does it help when this happens to pump the clutch pedal a few times?
JakeRobb is offline
RUENUF
03-13-2016 03:37 PM
blac94Z
11-04-2015 01:59 PM
TGGodfrey
08-18-2015 06:08 PM
dolfan324
07-17-2015 10:34 PM
Firehawk#69
09-08-2002 09:23 PM
Quick Reply: No Reverse 2001 SS
