69 Camaro LSA/6l90 swap
Old 09-19-2016, 02:41 AM
jamesrice's Avatar
I'm installing a LSA and 6l90 package out of a CTS-V.
I can't find much on the trans. What drive shaft can be installed to make this work on a 12 bolt rear. What parts need to be changed to make it work? Anyone that may have done this swap, I would appreciate any help you may have.
jamesrice is offline
Old 09-19-2016, 02:41 PM
Super Moderator
JakeRobb's Avatar
Re: 69 Camaro LSA/6l90 swap
I'm pretty sure you're going to need to have a custom driveshaft made for that combination. You'll probably work harder trying to find someone who knows exactly what you need that simply measuring for it yourself.
Contact a custom driveshaft shop. They'll tell you exactly what measurements you need to take, and give you options -- what material, what kind of U-joints, etc.
Good luck! That will be a fun combination.
Also, if you're not familiar with Mark Stielow's Red Devil project, I strongly suggest you google it.
JakeRobb is offline
Old 09-28-2016, 10:23 AM
KW Baraka's Avatar
I don't know how far down the road you are with gathering parts for the install.....but hopefully, this'll help --->> MuscleRods 67-69 Camaro LS Conversion Kit
KW
KW Baraka is offline
Old 01-29-2017, 07:42 AM
jamesrice's Avatar
I have gotten everything but the driveshaft at this point. Once everything is together, I am taking it to a driveshaft shop in Charlotte and they'll take it from there.
This is a lot more expensive than I originally planned that's for sure.
TT350
01-17-2016 11:38 AM
ChrisFrez
12-15-2015 10:14 PM
CamaroZBoy
09-01-2002 09:48 AM
Bill'sWS6
08-24-2002 09:47 PM
turbo_Z
08-19-2002 10:50 PM
Quick Reply: 69 Camaro LSA/6l90 swap
