Strange rattling noise from engine bay
Old 08-05-2014, 02:00 AM
Justin11141's Avatar
so im driving home one night from work and i hear a strange metal against metal sound..like cling cling clang. then i start hearing a weird low rattling noise from the front drivers side of the engine bay. around the valve cover and end of the headers. it only rattles when i accelerate and as i push the gas harder it gets louder. i notice that theres a hole on top that i'd never noticed before and it pushes warm air out on idle. i believe its at the end of the headers but its some pipe. ( im not sure what the part is or called) i dont know if that hole is supposed to be there but it looks like there are threads in it. i have some pics but it wont let me post attatchments
Justin11141 is offline
Old 08-05-2014, 05:23 AM
Re: Strange rattling noise from engine bay
What year, what engine?
You can establish an "album" in the "Photos" section, and upload the pics, then link or embed them in your posts.
https://www.camaroz28.com/forums/sit...28-com-699204/
You need a "Signature" with basic info abut your car.
https://www.camaroz28.com/forums/lt1...nature-879835/
Injuneer is online now
Old 08-05-2014, 11:23 AM
I uploaded them
Old 08-05-2014, 11:26 AM
97 lt1
Old 08-05-2014, 02:37 PM
Originally Posted by Justin11141
I uploaded them
OK... now post a link to each photo you want us to look at in this thread. Or embed the images in a post with the [img] tags. There is a URL address in the box right below the picture that you can copy and paste.
Old 08-05-2014, 02:44 PM
And looking at your album, that is the connection on the header for the AIR pump discharge into the header. You either need a line from the AIR pump to a check valve, connected to that hole, or you need a plug in the hole to prevent exhaust from escaping, or air to be inducted. With it open, the noise you are hearing is a giant exhaust leak.
Make repairs rapidly, because that leak could cause the #1 cylinder exhaust valve to burn, and it's throwing off the A/F ratio seen by the O2 sensor, causing the PCM to add fuel the engine doesn't need.
Old 08-05-2014, 03:43 PM
So i shouldnt be driving it? Also i forgot to add i dont have catalytic converters does it make a difference ?
Old 08-05-2014, 05:06 PM
If you don't have a cat, you don't need the AIR system. First, with the engine running, verify that there is exhaust coming out of that hole. What you need ASAP is a threaded plug to close off the opening. Some headers use a 22mm oil drain plug, I think others use an 18mm drain plug.
My AS&M headers use a 22mm plug:
formula218
12-02-2014 04:27 PM
jayblev95
12-01-2014 06:55 AM
squarehead
11-21-2014 08:02 PM
kandied91z
08-04-2002 02:53 AM
Caps94ZODG
22
07-30-2002 08:45 AM
Quick Reply: Strange rattling noise from engine bay
