Not gettin gas to my motor..??
ok..well wen i go to turn my car on it will just crank but wont start..it sounds like the motor is not gettin gas..but thats my opinon..does anyone think i need a fuel pump?let me kno..thanks
-1994 chevy z28 camaro-
Re: Not gettin gas to my motor..??
Do the basics before attempting to fix the fuel pump. First, do you hear the pump kick on when the the key is turned to on position? Assuming that checks out, how old is the fuel filter?
ok like 2 weeks ago brang it to the shop for boggin out..they changed the plugs,wires,fuel filter and disturbutor..the car has 110,00 miles on it. yes i do hear the fuel pump turn on wen u turn the key
Attach a fuel pressure gauge to the Schrader valve on the fuel rails and check your fuel pressure. Fuel pressure should come up to around 36 psi and slowly decline after the pump stops (2 second time out). If the pressure drops quickly, the check valve in the fuel pump is shot and the fuel pump will need to be replaced.
WobblySausage
10-07-2015 10:09 AM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
