Does anyone know what goes here?
#16
Re: Does anyone know what goes here?
#17
GaryDoug, i found those wires but for some reason the last (IDIOT) owner cut the plug off of them....is it possible to buy just the plugin?..
#18
#19
Just curious...does anyone know of a diagram that shows all the sensor locations? I also noticed that my O2 sensors are not plugged in lol...this is turning out to be a real project....
#21
#22
I can't believe anyone owns one of these cars and hasn't already been there. It is an unbelievable resource, and has been there for 15 years. Plus, Rob/Shoebox has links in his signature.
4th Gen LT1 F-Body Tech Aids
#24
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
http://www.mediafire.com/?40mfgeoe4ctti
#26
Prominent Member
The location is the same but the location view diagram is not. It shows a square (2x2) 4-way connector instead of the correct rectangular (1x4) connector.
#27
Prominent Member
The source is:
For 1996:
pins= 12124075-L Delphi Connection Systems | Mouser
body= 12162190 Delphi Connection Systems | Mouser
Here is a body that is close to the 94 part number (12110188) but not exact: 12162188 Delphi Connection Systems | Mouser
You can browse the connectors, but do not trust the images to be accurate. Also, the 94 manual says it a Metri-pack type 150, not the type 150.2 found in the 96 manual and in the links above.
Edit: The links also point to a datasheet on the Delphi web site... but you have to re-enter the part number after getting to Delphi search. See the Documents tab and the 2d drawing (.tif) file for complete details including an options table.
#28
To add to the confusion - According to Shoebox's parts list, 94/95 with RPO KC4 (oil cooler???) have one part # for the IAC valve, and 95 W/out KC4), 96-97 have a different part # for the IAC valve.
Why would an auxilliary oil cooler change the IAC part #? Could it possibly have been with RPO "K34" (cruise control) that determines the IAC valve?
My 94 (very late production number, with KC4) has the in-line 4-pin connector. I just can't get to it (still recovering from shoulder surgery) to pull it off the sensor and check.
#29
Prominent Member
Here it is. Too bad I did not remember this source first:
EFI Connection, LLC - Item Details
They have the other style also (2x2).
#30
