The most RIDICULOUS horn issue ever
Old 01-03-2014, 10:56 AM
threehourshower's Avatar
This is driving me NUTS! and so far it doesnt seem like this has happened to anybody else.. anyway about a year ago i added a two 12v outlets on the same circuit as my stock outlet ('95 z28), one above the original and one inside the center console. this was primarily done so i could have a dedicated outlet for my passport radar detector. all was well for awhile, save for a weird issue where some of the car electronics would occasionally trigger the radar detector, like the horn. i can deal with false positives, so whatever. a few weeks ago though, the horn just started honking itself! while im driving or stopped, it doesnt matter. sometimes it starts to honk as soon as i lock and shut the door. it kind of stops when you play with the horn buttons, like a bad contact or something, but i had to pull the fuse, rendering my outlets useless. its definitely causing me some issues. anybody have any ideas? where should i start? i have no idea how to tear the airbag off the steering wheel...
threehourshower is offline
Old 01-03-2014, 11:49 AM
Re: The most RIDICULOUS horn issue ever
also somebody please move this to general tech for me, my bad
Old 01-03-2014, 01:53 PM
I'll move it.
Sounds like a problem with the horn relay, or the switches or slip-ring in the steering wheel.
Courtesy of Shoebox:
http://shbox.com/1/horns.jpg
Injuneer is offline
Old 01-03-2014, 08:37 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Try this while the horn is blowing and the Cigar/horn fuse is installed:
Unplug the Horn relay. Then plug it back in.
If you can feel the relay click, the problem is not with the relay.
If you feel no click, replace the horn relay. In the meantime, try smacking the relay on the floor hard several times. Then plug it back in. Sometimes that "unsticks" them.
GaryDoug is offline
sahlomonic
Parts Wanted
09-19-2015 10:17 AM
Jasonz28camaro
06-07-2015 09:14 PM
Jasonz28camaro
West South Central
06-07-2015 09:12 PM
cmdeshon
12-12-2014 10:51 PM
fpete1992
12-11-2014 03:51 PM
Quick Reply: The most RIDICULOUS horn issue ever
