97 3.8 heater core?
Old 01-09-2014, 09:38 AM
rswalley's Avatar
97 3.8 heater core?
i have no heat at all.i know the cooling system needs flushed,there is a bunch of old barrsleak or something throughout the system.but it has been my experence that even if heater core is clogged you will still get a little heat.on this car there is absolutely no difference between outside air temp & heat temp.garage i bought it from replaced raditor dont know why they diddnt flush system then. is there something to use to get the cooling system clean that will work
rswalley is offline
Old 01-09-2014, 10:18 AM
Re: 97 3.8 heater core?
Detach the heater hoses at the water pump, and force water through it both ways with a garden hose. Try to limit the pressure applied to the system, to prevent overpressuring the core.
Injuneer is offline
Old 01-21-2014, 02:30 AM
z281997's Avatar
Thermostat?
Sent from my SGH-M919 using Tapatalk
z281997 is offline
SergheiS
09-29-2015 08:56 PM
Fatdog2
09-16-2015 11:04 PM
Pwilson59
09-03-2015 08:47 PM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
ducttape1975
07-10-2015 06:29 PM
Quick Reply: 97 3.8 heater core?
