2000 Base Firebird 3.8 v6 SES cold p0306 PLEASE Help!!!
Old 11-01-2013, 07:22 PM
jason21308's Avatar
Angry 2000 Base Firebird 3.8 v6 SES cold p0306 PLEASE Help!!!
I've recently purchased this vehicle and have been doing maintenance to it for a couple weeks now but I cannot get this code to disappear. I've replaced the coil packs, the spark plugs and wires, the fuel filter, the oil and air filter and other things and it still won't go away. Is there anything else I can do? I do not want to put it in the shop, but it's looking like I might just have to. Recently the SES light has started to flash and then go away for a little while just to appear again later, and it's a little harder to start than I'd imagine it should be, and the car seems to idle pretty bad. It feels like it's rhythmically shaking when it idles now even when the light isn't on. ANY help or insight would be so appreciated. Thanks for your time.
jason21308 is offline
Old 11-02-2013, 10:15 AM
Re: 2000 Base Firebird 3.8 v6 SES cold p0306 PLEASE Help!!!
Try swapping #6 fuel injector with another cylinder, and see if the code follows the #6 injector. While you have the fuel rail off, pressure the fuel system by turning the key to "run" (not to "start") and see if the injector is dripping.
Do a compression check.
Check the valve adjustment.
Have the ignition control module checked.
Injuneer is offline
jayvar
02-02-2015 10:00 PM
Brake_L8
01-20-2015 09:44 AM
01-13-2015 09:52 PM
kizz
18
03-16-2004 10:41 AM
kizz
25
08-02-2002 08:21 PM
Quick Reply: 2000 Base Firebird 3.8 v6 SES cold p0306 PLEASE Help!!!
