Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need help: how is your fuel tank o-ring/lock ring configuration?
Old 02-03-2012, 01:02 PM
slimdawson's Avatar
Question Need help: how is your fuel tank o-ring/lock ring configuration?
I have a tank that has a lock ring that is held down by studs/nuts, NOT the kind of lock ring that twists into place.
I'm trying to find a new o-ring and the parts stores around here only have the twisting ring and o-ring. The o-ring provided in the kits is too small(diameter). I've tried multiple cars trying to find something that works but they all look the same. corvettes, impalas, caprice, older camaros, newer camaros, pontiacs.
BTW, this tank supposedly came out of a 4th gen fbody. I got it at a junk yard complete with fuel lines so my lt1 swap would be easier.
slimdawson is offline
Old 02-03-2012, 02:08 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Re: Need help: how is your fuel tank o-ring/lock ring configuration?
I recently replaced the factory fuel tank on my car with an aftermarket tank. The aftermarket tank had twist on lock ring. I also replaced the fuel pump and sending unit. I believe the fuel pump, sending unit and new tank all came with O-Rings and they were all the same size.
BTC is offline
Old 02-04-2012, 12:32 AM
That Camaro Guy's Avatar
94Z28 car owner checking in here. My car was built in December of '93 and has the type of fuel tank cap you describe. The tank has studs and the lid is held on by tiny nuts, I can't remember the size. Not sure what else to say, but there you go.
That Camaro Guy is offline
Old 02-04-2012, 10:19 AM
slimdawson's Avatar
Cool, thanks. I'll have the guys check on a 94 model. I thought I covered that year but they couldn't find anything.
Old 02-04-2012, 11:51 AM
BTC
BTC's Avatar
My factory '94 tank had a ring that was secured with studs & nuts. My new aftermarket tank has the twist ring. The O-Ring on both tanks was the same size.
Do you have any pictures of your tank? I'm pretty sure the tanks on the LS1 cars are different. I'm not sure about the opening on those tanks, but perhaps you have a tank off one of those cars.
BTC is offline
Old 02-04-2012, 12:13 PM
slimdawson's Avatar
I thought the ls1 cars had plastic tanks. I don't have any pics atm. Called the stealer but the parts dept was closed so I'll check monday.
Old 02-04-2012, 01:57 PM
sandman2100's Avatar
I just dropped my tank about an hour ago to install a new fuel pump. Same style with studs and nuts. Car is a 97
sandman2100 is offline
Old 02-04-2012, 02:15 PM
BTC
BTC's Avatar
I believe the 1st year LS1's had metal tanks, but I'm not positive.
BTC is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Magenta_Hearts
03-05-2015 07:01 AM
guionM
9
08-29-2002 01:48 PM
guionM
18
07-11-2002 01:45 AM
Quick Reply: Need help: how is your fuel tank o-ring/lock ring configuration?
