Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 Camaro Z28 Fuel Tank Pressure
Old 08-01-2015, 01:48 PM
Alibi's Avatar
I have a 1995 Camaro Z28. I put a new fuel pump and fuel filter in it and now it builds pressure in the tank, gas boils, and the vent valve pours fuel everywhere, the engine bogs down and dies. I have been told it can be anything from a vacuum line for Evap Solenoid or a plugged/defective charcoal canister. Any suggestions?
Alibi is offline
Old 08-01-2015, 07:50 PM
Re: 95 Camaro Z28 Fuel Tank Pressure
What pump did you install?
Pressure comes from excessive heat, causing large amounts of fuel to vaporize. May be a problem with a faulty or incorrect pump.
What was the original problem that led you to replace the pump.
Are you sure you connected the vent valve and EVAP canister lines to the correct pipes on the sender assembly?
Injuneer is offline
CamaroHeed
03-18-2020 09:50 PM
Brandon Wittmer
12-03-2014 09:28 PM
siguy
11-27-2014 10:07 AM
grendal
04-15-2010 05:20 PM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: 95 Camaro Z28 Fuel Tank Pressure
