Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 Camaro 3.4 not starting
Old 11-15-2014, 06:02 PM
dkishton1486's Avatar
Hello all I have a 95 Camaro with a 3.4. The other day I was driving and it started to misfire and now it will not start at all. All it will do is crank. I have 40PSI at the fuel rail, I have put in new coils and a new ignition control module and it is getting spark but it will not start. I am at a total loss on this one
dkishton1486 is offline
Old 11-15-2014, 06:24 PM
Re: 95 Camaro 3.4 not starting
Have you scanned it for codes?
Injuneer is offline
Old 11-15-2014, 06:36 PM
I put my scanner on it and it did not show any codes
Old 11-15-2014, 08:06 PM
An OBD-1 scanner?
Injuneer is offline
Old 11-16-2014, 07:23 AM
My sanner does both obd1 and obd2
Old 11-16-2014, 09:45 AM
There are a few higher end OBD-1/OBD-2 scanners that will not scan the 4th Gen OBD-1 cars, because they are looking for a 12V pin in the ALDL connector, and there is none. I suspect your 95 may have the 16-pin OBD-2 style connector, just like the 95 V8 models, and may require an adapter plug to connect to the OBD-1 portion of the scanner. Does the scanner indicate that it is "connected"? Has it ever worked on your car?
Injuneer is offline
Old 11-16-2014, 08:03 PM
I have a GM Tech II. When I pulled the history codes only code stored was 0082 which is Ignition Control 3x
Old 11-16-2014, 09:27 PM
DTC 82
You found your problem. The PCM needs the 3X low resolution signal from the 3X crank position sensor, in order to tell the ignition control module when to fire the coils. No signal = no fire.
Injuneer is offline
Old 11-16-2014, 09:29 PM
Only weird thing is that code was stored but when I checked the coils I was getting spark from them
Old 11-17-2014, 07:20 AM
Clear the code, and see if it comes back when you try to crank it.
Injuneer is offline
Old 11-17-2014, 05:49 PM
Ok I replaced the 3X crank sensor and it still just cranks and cranks . It acts like it wants to start but it wont. On the Tech II it shows engine RPM while cranking over.
Old 11-17-2014, 07:26 PM
Did you try clearing the code before buying a new sensor? If it cleared, and didn't reset, it wasn't the problem.
Injuneer is offline
SpeedJunkee
01-27-2015 10:02 PM
ChrisFrez
12-07-2014 06:01 PM
NewsBot
12-03-2014 12:30 PM
jdohman
08-21-2002 07:57 AM
Eric H
08-10-2002 06:39 AM
Quick Reply: 95 Camaro 3.4 not starting
