twin turbo for 95 lt1 camaro
Old 07-24-2004, 11:38 PM
justinshupe95's Avatar
Hi i was wanting to know the best twin turbo i could get for my 95 z28 camaro..it's all stock..i have 4000 dollars to spend on it so could i get a twin turbo kit with intercooler and everything to go for 4000 dollars..or will i need to get a supercharger and other stuff..let me know what u think..thanks
justinshupe95 is offline
Old 07-24-2004, 11:52 PM
SMOKNZ's Avatar
Re: twin turbo for 95 lt1 camaro
You might be able to build a kit for that much if your willing to do the work. There are alot of other things like driveline and fuel system to go along with it. Plan on way more than $4K. Used supercharger would probably be your best bet. If ya can pick one up for 2 grand or so, and upgrade the fuel and ignition system, keep it under 8 psi intercooled, throw in a cam and tuning and you've hit your limit.
Bill
SMOKNZ is offline
Old 07-25-2004, 01:36 AM
97WS6SCharged's Avatar
You could build a single turbo setup with the PTK hot parts. Just take Bill's advise and keep the boost under 8 psi.
97WS6SCharged is offline
Old 07-25-2004, 07:12 AM
irishz28's Avatar
if the car is bone stock dont put turbo or supercharger on it. concintrate on the things that need to be upgraded in order for your car to be able to handle that kind of power. If you have an a4 you will kill that w/ a stock motor, and also the rear go 12 bolt. Also work on your suspention, definatly subframe connectors, if you got t-tops and you put the kind of power that a super charger or turbo makes you will tweak the frame and shatter the t-tops. let us know more about your car and we will help you spend that 4000 right.
irishz28 is offline
LeftoverChinese
01-14-2024 03:03 PM
Highlander
01-12-2020 02:13 PM
MadMav
02-06-2015 11:02 PM
cmdeshon
12-12-2014 10:51 PM
carcrazyQT
09-03-2002 02:51 PM
Quick Reply: twin turbo for 95 lt1 camaro
