Tunning Recommended 93Z? With Cam?
So I'm still debating on a few things here and I don't know enough about tuning to make a sound decision.
Firstly, I have most of the bolt-ons for my car, (cold air, headers, borla cat back, 1.6 rockers/springs, hypertech chip, etc) however I've never had a custom tuning, unless the hypertech kinda substitutes in that regard.
I was thinking about getting a cam, but don't know if tuning is required? I only want to get a very mild cam, since its a weekend driven car and I don't do much else with it. Just want a few extra horses outta it.
So I guess my questions are, is a tune required for such a basic cam? If I don't get a cam, should I get a custom tune anyways and spend the money there and see some minimal results?
Any recommendations or questions on how to go from here? Thanks as always!
Re: Tunning Recommended 93Z? With Cam?
Yes you need will need a tune after cam. The TPS closed timing will have to be adjusted for a smoother idle. If you have an A4 then the 550/650 RPM stock idle in drive/netrual will run like crap. Also a good tune will alter your main and extended timing tables to take advantage of your new cam's power curve. And will tweak you VE tables and PE mode tables for you custom mods. Lowering the fan turn on's and running high octane will help keep knock away as you crank up the timing. You can then sell your Hypertech on E-Bay.
Thanks for the reply. So between someone like Elliottsportworks.com or Ed Wright, are there recommendations on who is better or whatnot? Would I not have to send in my hypertech then, they would just program and ship me a chip? Is that how it works?
I'm in the same boat (a 93),with similar bolt on's, and a G M Hot Cam. I cannot find a tuner here in the New England area. It should will need a dyno and chip burning capabilities to do it properly. I was told that if you could datalog, you could send that info to someone and they could burn a chip with that data. I haven't done that. I also have a mailorder chip installed. It is better than nothing at all, but needs tuning.
They will burn you a new chip.
212/222 .563/.562 114 LSA. – Idle-5800 RPM
“Sleeper cam” with smooth idle improving HP and TQ everywhere.???
Or buy like a compcam?
Looks like a lot of lift for stock heads, which appears to be what you are running. They aren't going to flow very well at 0.56+ lift. I'd go for a bit more duration, and a bit less gross lift. I like a 114LSA, because it keeps the bottom end stronger, and makes it more manageable on the street.
jasonduaine
Exhaust System
03-20-2015 09:00 AM
454Corvair
08-10-2002 07:02 AM
