Scan9495: Free OBD1 scan app for 93/94/95 LT1
Old 03-28-2015, 08:32 PM
  #241
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
Originally Posted by moparman
Will this work with other GM models of those years?
In theory, yes if they are LT1. Some cars like the Corvette have other supervisory controllers as well that can "get in the way" of communications. Performance on those cars is intermittent.
GaryDoug is offline
Old 03-28-2015, 08:43 PM
  #242
moparman's Avatar
Thanks.
moparman is offline
Old 04-20-2015, 06:45 AM
  #243
horridohutch's Avatar
Gary I am just getting this setup in my laptop. Need the driver installed and cable. The older build your own cables could be "bricked", can I avoid this by purchasing the $60 cable from aldl.com? Or should I not worry about it because the older cables are no longer being shipped? Just trying to keep it simple.
I also am really looking forward to troubleshooting an ABS light and getting some data logs to my tuner. This has had to have taken a lot of work, thank you for your time and effort, mucho appreciated!
horridohutch is offline
Old 04-20-2015, 07:49 AM
  #244
Prominent Member
GaryDoug's Avatar
Originally Posted by horridohutch
...The older build your own cables could be "bricked", can I avoid this by purchasing the $60 cable from aldl.com? Or should I not worry about it because the older cables are no longer being shipped? Just trying to keep it simple.
Yes, the purchased cables are safe to use. The "bricking" affects all knock-off copies of the chip, past and present; and those are still vulnerable if you don;t take special measures to use only the older drivers.
Red Devil River is another good source for a safe cable.
GaryDoug is offline
Old 04-21-2015, 05:16 PM
  #245
warmeck's Avatar
garry can i use a data link cable from an inniova 3140 and attach it to a usb as shown in post #1? i do see a lot more wires to work with would that be a problem?
warmeck is offline
Old 04-21-2015, 05:33 PM
  #246
Prominent Member
GaryDoug's Avatar
Are you talking about cutting off the 12-pin or 16-pin connector and using that? Or are you talking about using the entire Innova cable? I have no idea how the Innova cable is configured. You would have to investigate that. The only pins needed for the 12-pin connector (year 94) are A and M. The only pins needed for the 16-pin connector (year 95) are 4/5, and 9. You can buy a cheap 12-pin cable to use for about $5 or a cheap 16-pin connector to use for about $3.
GaryDoug is offline
Old 04-21-2015, 05:43 PM
  #247
warmeck's Avatar
would this one work
Amazon.com : OBD OBD2 16 Pin Connector Diagnostic Adapter for GM 12 Pin (to Daewoo) : Vehicle Audio Auxiliary Adapters : Car Electronics Amazon.com : OBD OBD2 16 Pin Connector Diagnostic Adapter for GM 12 Pin (to Daewoo) : Vehicle Audio Auxiliary Adapters : Car Electronics
warmeck is offline
Old 04-21-2015, 06:17 PM
  #248
An OBD-1 scanner has a 12-pin connector. The correct cable for Scan9495 will have a 12-pin connector. Your 94 has a 12-pin connector. You don't need an "adapter".
Injuneer is offline
Old 04-21-2015, 06:24 PM
  #249
warmeck's Avatar
i understand that i bought it to cut the 16pin side off and connect it to the usb via post #1 on garys write up
warmeck is offline
Old 04-21-2015, 10:11 PM
  #250
Prominent Member
GaryDoug's Avatar
Probably. Cut off the 16-pin connector, and use the 12-pin connector and short pigtail for the new cable.
GaryDoug is offline
Old 04-22-2015, 12:08 AM
  #251
warmeck's Avatar
just saw on page 2 i guess i should read the whole thread first. lol
warmeck is offline
Old 04-23-2015, 05:31 PM
  #252
warmeck's Avatar
The usb is not being recognized and the app winter let me scan saying I don't have a port?
warmeck is offline
Old 04-23-2015, 05:54 PM
  #253
Prominent Member
GaryDoug's Avatar
You either haven't installed the driver or haven't installed it correctly.
GaryDoug is offline
Old 04-23-2015, 10:28 PM
  #254
warmeck's Avatar
on my desktop it gives me a port but on my laptop it says no port avaiable which makes no sense.
warmeck is offline
Old 04-23-2015, 10:29 PM
  #255
warmeck's Avatar
Getting code 10 sometimes 27,29 for usb
warmeck is offline
Quick Reply: Scan9495: Free OBD1 scan app for 93/94/95 LT1
