Engine misses when warmed up.
#17
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Engine misses when warmed up.
If you don't want to spend a lot, get the one I posted earlier (MS310) for about $20. It's cheap and the numbers are small also and a little hard to read but shows all the generic real time OBD2 data, not just codes. I keep one in my car all the time.
#19
I now have a related problem. I broke the plastic cover the sensor wire clips to. I glued it back on in the way I thought it was supposed to be. However, the engine will not start at all although I am getting spark. Would the temperature sensor wire connection being reversed be enough to make the engine not even fire over, or is this another issue?
#22
What you need is a data log showing what is happening in the PCM when the engine is missing, compared to when it isn't missing, and showing the transition from no miss to missing. I know how to do that with OBD-1. Since they stopped selling AutoTap I'm not up to date on data logging in OBD-2.
#26
Do you have spark at the coil wire (Injuneer)?The coil wire(believe me) is one of the weak links in the system.Also look for corrosion around the coil terminal for the coil wire.Hope this helps.
#28
I have charged and checked the battery. It is nearly new and is fully charged. I got a fuel pressure tester from O'Riley's and it shows absolutely no pressure. The fuel pump fuse is not blown but I need to locate the relay and see if it is getting current. Is there anything I could have accidently disconnected when I was accessing the water temp sensor in the front of the engine?
#29
Did you tighten the connection for the pressure tester tight enough to depress the valve core in the Schrader valve? No pressure reading unless the core is depressed.
Can you hear the fuel pump run for two seconds at key on? If not, use the fuel pump prime connector near the PCM to bypass the PCM fuel permit interlock/PASS-Key system and the fuel pump relay. See Shoebox's photo:
http://shbox.com/1/fuel_pump_prime.jpg
Apply 12V to the connector.
Fuel pump relay is under the "dead pedal", far left of the driver's footwell. Again from Shoebox:
http://shbox.com/1/fuel_pump_relay.jpg
#30
Thanks Fred. Good to know. I will try your suggestions. I am hard of hearing and do not hear a 2 sec. sound. I had my wife listen, but all she heard was a light continual whirring, but probably a fan.
