97 z28 audio questions
Old 12-02-2012, 06:54 PM
mutlyi4's Avatar
ok i got two questions
1 i was told that wiring the high inputs on an amp would produce bad sound quality is this true or was the guy just trying to sell me more stuff?
2 i just got the car about 3 weeks ago the security light is on all the time i was told it came on after they put an aftermarket radio in could this be true and if so how can i fix this problem?
thanks for any response
mutlyi4 is offline
Old 12-03-2012, 03:12 PM
parkers Z28's Avatar
Re: 97 z28 audio questions
Answer to question #1 yes and no really depends on the quality of the audio equipment that you
have purchased ... I would recommend that you use rca's
#2 when I changed out the radio in my 96 the light did not appear
parkers Z28 is offline
Old 12-03-2012, 05:24 PM
mutlyi4's Avatar
ok thanks for the info
mutlyi4 is offline
Old 12-03-2012, 07:19 PM
Did you disconnect the battery when you installed the radio ??
have you tried to disconnect battery to reset the light leave disconnected for 20 min or so
Welcome to the site. lots of good folks on here with a vast amount of knowledge
Old 12-03-2012, 08:27 PM
96 Z 28's Avatar
#1 - High Level Inputs typically require a "Line Level Converter" in order to adjust the gains. Some amps can handle this level of input, some just RCAs. I prefer not to go that route though, as your essentially amplifying a signal that's already been amplified, so technically not a clean signal and much more opportunity for distortion.
#2 - If wired correctly you should not have an SES Light. There could be something dumb like a crossed wire, or it may have nothing to do with the Stereo Install. Without the code it's like throwing darts blindfolded... You should probably scan the code to determine what it points to as in issue.
96 Z 28 is offline
Old 12-03-2012, 08:34 PM
moparman's Avatar
Someone probably botched the install on the radio, and that's why the security light is on.
moparman is offline
Old 12-04-2012, 09:18 AM
mutlyi4's Avatar
ok i pulled the radio got a new harness and reinstalled still got the ses light all the audio shops in town say the car should take the standard cheap harness nothing special so im not sure and my scanner will not do security system codes and the dealer wants $130 just to scan it which i think is way to much
mutlyi4 is offline
Old 12-04-2012, 11:15 AM
moparman's Avatar
SES and Security light are not the same. Few consumer grade scan tools will do anything with the Security light.
moparman is offline
Old 12-05-2012, 05:27 PM
mutlyi4's Avatar
ahh ok so whould the radio cause the security light or would this be something else entirly
mutlyi4 is offline
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
Brian Demeter
08-21-2002 02:07 PM
Brian Demeter
08-17-2002 08:07 PM
Zomie
07-22-2002 07:43 AM
Quick Reply: 97 z28 audio questions
