Autocross and Road Racing Technique There is more to life than a straight line
LS1 power steering cooler
Old 12-14-2004, 02:06 PM
NoFear95's Avatar
Anyone with an LT1 running these? Pictures? What items are needed to install it besides the LS1 cooler itself?
NoFear95 is offline
Old 12-14-2004, 06:59 PM
NoFear95's Avatar
Re: LS1 power steering cooler
Nobody?
NoFear95 is offline
Old 12-15-2004, 11:24 AM
Jerm's Avatar
Location: You know when they Quit Suckin that something is Wrong!!!!
A cool write-up w/ pics
Jerm is offline
Old 12-15-2004, 02:09 PM
NoFear95's Avatar
Thanks. I found that one on a search. But the LS1 cooler looks like the way to go and you can pick them up for $30ish. I know someone has to be running the LS1 PS cooler.....
NoFear95 is offline
Old 12-18-2004, 11:15 AM
Z28barnett's Avatar
I am running the LS1 p/s cooler.
It mounts in the driverside rad hose.
I got one with the hoses and p/s lines on it.
The cooler is marked as to the direction of flow rad/engine side.
You have to remove the LT1 return line from the rack and cut the swaged clamp near the center of the rack so you can remove the hardline part of the LT1 p/s retun hose.
Install the LS1 line from the LT1 rack to the cooler.
Buy a length of p/s hose and a barbed hose fitting.
Connect the output from the cooler to the Lt1 retun line with the barbed fitting.
Clamp everything and get some black split loom to protect the hose.
The cooler is a little long and you have to very carefully cut the rad hose into two correct lenghts. The fit is not great but it works ok.
Ls1 hose might work better since it has a better bend to it. I used the Lt1 hose because it came with my HiMiler kit. Problem area is the bend on the drivers side of the rad it wants to pinch down.
It has worked for 1000 miles, might have slightly increased the engine temp, not sure about that might be the sensor seeing some heat from the headers.
Z28
Z28barnett is offline
Old 12-18-2004, 05:23 PM
NoFear95's Avatar
Z28
cool you'll have to snap a picture for me and send it over, i would sure love to check it out.
NoFear95 is offline
Old 12-19-2004, 01:37 PM
MustangEater82's Avatar
I just picked one up for $35 on ebay, but I have a v6, different setup. But they can be picked up for real cheap, just need to fabricate it in
MustangEater82 is offline
Old 12-19-2004, 06:31 PM
Z28barnett's Avatar
You can't really see much of it once it is installed. It is mostly under the intake hose. I don't have a camera.
Old 01-02-2005, 06:00 PM
ElkyRacer's Avatar
Why not use the tranny cooler section of a A4 radiator for a power steering cooler? It would be the same thing as the LS1 cooler, but simpler and less cluttered in the engine bay.
Kyle
ElkyRacer is offline
Old 01-04-2005, 02:56 PM
Z28barnett's Avatar
I have a factory 6spd, no A4 cooler on the rad.
Buy a new rad for $30, I don't think so.
Ls1 cooler is about the size of a medium flashlight, what clutter?
Have you ever looked at an LS1 Cooler?
Old 01-04-2005, 08:18 PM
ElkyRacer's Avatar
Sounded like a good idea to me! Also doesnt add all that extra weight! Yes, and thats sarcasm. And yes Ive seen a LS1 cooler. You were the one who mentioned the fact that it doesnt fit very well. I just wondered seeing I had a A4 radiator in my car right now.
Old 01-05-2005, 07:55 PM
WOOS1's Avatar
Z28barnett, thanks for the info. I've had an LT1 cooler that I bought off of Ebay for about 15 months. Now I need to get it on there!
WOOS1 is offline
HectorM52
07-30-2017 11:46 AM
mspennyhughes
03-01-2015 03:50 PM
XtremeLt1
09-13-2002 08:50 PM
Quick Reply: LS1 power steering cooler
