Autocross and Road Racing Technique There is more to life than a straight line
Attn: Road racers
Old Mar 28, 2003 | 05:17 PM
TEG99SS's Avatar
Question Attn: Road racers
This question is for you A sedan guys. . . I have a 93 Z28 that is completely stock, I road race the car and heard through the grapevine there is a way to keep from blowing power steering pumps by changing the pulley to a larger diameter. Is this true? if so what size pulley and what belt should I use? I have had it fail a few times at high speeds and know it neds to be replaced.
(It moans like a 70's **** star!!)
Any advice is helpfull.
The wall is a bad place to be on raceday!!!
Old Mar 28, 2003 | 10:35 PM
1Z2Z's Avatar
Many guys install a cooler in the PS system to keep the fluid temp down, seems to improve the life of the pump. Do a search, there have been a couple threads on this recently and there are a couple how-to links as well. Mike
Old Mar 28, 2003 | 11:19 PM
Dr.Mudge's Avatar
If its already dying I dont know that you can save it now. People are talking about an under drive crank pulley, I haven't seen anyone actually take off and install a larger PS pulley yet.
Old Mar 29, 2003 | 03:45 PM
#7's Avatar
1Z2Z,I read his post awhile ago...I assumed that since he's been racing that he already knew about the PS needing a cooler and thought he was talking about some sort of problem with the pump not be able to stand up to sustained high rpms"blowing up" as in seals or internals from over pumping or something while using a cooler.Didnt bother with tellin him about the cooler and was waiting for some replies cuz this intrigued me and kinda seems possible.And a bigger(smaller) pulley would be less revolutions... under pumping @ higher rpms.
But if he doesnt have a cooler he definitely needs one(thats the prob.) and as advanced as his symtoms are and the fact he's lost a pump already before his Rack will fail in due time like mine did also even after puttin a new pump/cooler in.
Old Mar 29, 2003 | 03:59 PM
apex's Avatar
Most W2W guys will install the smallest crank pulley they can find in an effort reduce all the speed of all the accessories..power steering, alternator,etc.
Old Mar 29, 2003 | 04:41 PM
#7's Avatar
Originally posted by #7
.And a bigger pulley would be less revolutions...
Oh,Duh yeah the smaller would be less.
Old Mar 29, 2003 | 05:09 PM
TEG99SS's Avatar
Yeah, I already know I have to replace the pump, but when I do I want to fix the problem right so I won't have to do this again. I already ordered the cooler and will install that on a brand new pump!
Thanks for all the help!
Old Mar 30, 2003 | 10:26 PM
Dan946spd's Avatar
This is something I've always wondered about but never needed to worry about. I road raced the heck out of my car and have never had a problem with the power steering pump. I know its not cause I am not driving the car hard enough.
However, I've never heard anyone mention the pulleys. Ever since I have been racing the car I have had BBK underdrive pulleys. I wonder if this is why I have never had the problems. I just change the fluid often and beat the crap out of the car. Best of luck.
Dan
Old Mar 31, 2003 | 11:38 AM
All_Z_Way's Avatar
LS1 powersteering pumps seem to be more proned to failure than LT1 pumps...most likely a result of the external fluid tank.
However, I do not have a PS cooler, but I do have the underdrive pulley and I haven't any problems with my car at the track. It has puked out a little fluid when overfilled at the track though.
Old Mar 31, 2003 | 11:47 PM
Kris96WS6's Avatar
What is a good PS fluid
Since were on about power steering, anyone have recomendations on good PS fluid?
Thaks
Old Apr 1, 2003 | 10:03 PM
94bird's Avatar
Re: What is a good PS fluid
Thaks
If you take the car to road courses and don't have a PS cooler, I'd use Redline. I have an underdrive pulley and a cooler and just use Valvoline semisynthetic - much cheaper.
Formula Steve
Sep 19, 2023 08:31 AM
NewsBot
Sep 30, 2015 04:20 PM
Z Power
Sep 19, 2015 11:19 PM
damnyankee36
Sep 9, 2015 07:06 PM
Catmaigne
Jul 14, 2015 05:17 PM
