Top End?
Old Mar 27, 2003 | 05:12 PM
jayjay's Avatar
Top End?
Hello.. I was wondering how is the top end on the lt1's.... And is it true the speedos with 150mph dont have the speed govenor?/
Old Mar 27, 2003 | 06:02 PM
COMNBYU's Avatar
when you say "top end", are you reffering to the motor, or speed of the car??
if you're talking about the motor, well, i think it's ok for a stock car. it's got descent heads, an "ok" cam, and a state-of-the art (for its time) intake design.
as for the speed top end, it's definately better than the previous range of 3rd gen 5.7s, but it's no LS1, which is what most people compare it to nowadays.
lastly, the govenor on these cars came on vehicles that did not have Z rated tires and it is controlled by the PCM. that limit is about 120. BUT, even the govern'd cars can still have the 150 speedo. the speedo has nothing to do with the limiter.
jon
Old Mar 27, 2003 | 06:38 PM
viperkiller's Avatar
ive been told by gm reps thr lt1 is balenced to 8000 i wouldnt take that chance persanally id stay around 6300 thats where my limit is set i know that wasnt exactly your question
as far as speed goes i have no limiter on speed only on rpm
so with 2.23 gears and 6300 you do the math
have done it once thout i blew the motor when i hit the rev limit
if you didnt know everyone i talked to said their car tach is about 300 to 400 rpm high
Old Mar 27, 2003 | 06:56 PM
jayjay's Avatar
thanks...
i hear a lot of camaros.. z28's say they have a 3.23 gear option.. wasnt that stock with all z's??? or what... and how do you know what gears you got...
Old Mar 27, 2003 | 07:08 PM
the a4 could have 2.73 or 3.23
the m6 were 3.42 not shure if they had an option
the quickest way ive been told is if your car has the 1st gear selector its 3.23 if you can only shift to 2nd you have 2.73 when you pull the shifter down does it have a one or does it just go to 2nd
Old Mar 27, 2003 | 07:20 PM
Hybrid86Z's Avatar
A4 = 2.73's (standard gearset) or 3.23's (performance rear axle, included tranny cooler, 3" aluminum driveshaft, and 3.23 gearset)
M6 = 3.42 gearset standard, no other options.
Old Mar 27, 2003 | 08:50 PM
krispy's Avatar
so wait, if i have the 3.23 i also have a tranny cooler and aluminum driveshaft, cause im pretty sure the driveshaft is rusted
Old Mar 27, 2003 | 08:59 PM
i have steel shaft and no cooler
well i put aftermarket cooler on it
Old Mar 27, 2003 | 09:02 PM
Carlos01SS's Avatar
Re: Top End?
FYI...
93 Z28 with manual 6-speed top end is 155 in 5th, redline 5800rpm.
In 6th, it only hits 150 due to overdrive.
Old Mar 27, 2003 | 09:30 PM
95m6's Avatar
95 Z/28 M6
162 mph...drag limited...
Old Mar 27, 2003 | 09:33 PM
FireAm94's Avatar
The official top speed was listed as 153 mph.....my car....when it was an A4 went 154 mph with k&n and flowmaster muffler only.
Joe
Old Mar 27, 2003 | 09:47 PM
Every auto has a cooler in the radiator. No auxillary tranny coolers were offered. Only the 1LE LT1's came with aluminum driveshafts.
Old Mar 27, 2003 | 10:05 PM
FireAm94's Avatar
Yeah...Rob is right. I bet you're thinking of the oil cooler that not all cars had.
Joe
Old Mar 28, 2003 | 10:55 AM
CODY BEHNKE's Avatar
Heres what a couple of magazines got for top speed
1995 Camaro Z28 - 155mph
1995 Trans Am - 157mph
1997 Formula - 158mph
Victor Lamb
Aug 26, 2017 02:52 PM
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
