Polyfill good or bad
Old Mar 27, 2003 | 08:00 AM
lil305gta's Avatar
Has anyone used this with good results? What is the benefit and what are the disadvantages?
Old Mar 27, 2003 | 08:06 AM
LS1 RULZ's Avatar
Polyfill fools the driver into thinking that the enclosure is bigger than it actually is. It does this by slowing down the sound wave inside the enclosure. I've been building speakers for a few years now and I don't hear any difference between stuffed and un-stuffed boxes. It's cheap to buy (you can get it at any fabric store) so go ahead and experiment with some.
Old Mar 27, 2003 | 08:23 AM
lil305gta's Avatar
Thanks for the quick help bro. From your experience how much do you reccommend? I have Kicker XPL 15's and will be installing an Orion 1000 Class D amp.
Old Mar 27, 2003 | 08:32 AM
LWillmann's Avatar
Ok, in my experience the bass note seems to "hold together better" or distort less. It also seems to deepen the response because the air mass is moving slower.
With that being said, the general rule of thumb is 1-1.5 lbs of polyfill per cubic foot of air space inside the enclosure.
Old Mar 27, 2003 | 08:53 AM
LS1 RULZ's Avatar
I was always told to use 1/2 to 1 pound of fill per cubic foot. Leave it fluffy inside the enclosure. Don't pack in down any. And be sure to keep it away from the cone.
Old Mar 28, 2003 | 08:47 PM
BMC95TA's Avatar
I have had good experiences with stuffing boxes with polyfill. It seems to give the sub deeper bass and tighter response
Old Mar 30, 2003 | 11:45 PM
lil305gta's Avatar
Loss of deep bass & volume
Fellas did it seem like you llost volume and the deep boom onjce poyfill was added? Sounds much cleaner but I think I lost some volume.
Old Mar 31, 2003 | 12:11 AM
BMC95TA's Avatar
I do not feel that it sounds like I lost any volume, but just improved the overall sound of the sub. I am not saying its a night and day difference but I feel the subs hit "cleaner" with polyfill.
Old Mar 31, 2003 | 05:59 AM
LS1 RULZ's Avatar
If you have the fill packed in too tightly you may loose a bit of performance. Having the fill packed tightly will reduce the internal volume of the enclosure.
Old Mar 31, 2003 | 11:14 AM
RallyRedTexan's Avatar
Re: Loss of deep bass & volume
Ployfill does displace some volume in an enclosure, but it slows down the waves more than it displaces the volume hence amking it wound like a larger box. The deeper play that everyone is describing is what a sub will sound like in a larger box.
Old Apr 3, 2003 | 09:37 PM
BadAndy743's Avatar
Can you use polyfil in a sealed box or just a ported box?
Old Apr 3, 2003 | 10:50 PM
Sealed box is fine.
Old Apr 4, 2003 | 05:40 AM
LS1 RULZ's Avatar
Usually sealed enclosures use fill and vented enclosures use batting on the walls of the enclosure.
Old Apr 4, 2003 | 04:18 PM
rotwiler's Avatar
When I took apart my JL audio Powerwedge box it was filled with poly fill and then a flat piece of batting to protect the sub from the factory. I have used this box for over a year and had no problems, so I reused the polly fill and batting in my millhouse box and I am impressed with the way it sounds.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
mattszm6
Dec 14, 2014 07:09 AM
kizz
18
Mar 16, 2004 10:41 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
