thermostat ?
Old Mar 26, 2003 | 08:35 PM
Fbody1's Avatar
thermostat ?
what is the differnce between the 160 degree thermostat that hypertech sells ( looks like the stock one w/spring ) and the cheap one at autozone , pep boys ,and why should I buy the hypertech is it better for some reason
Old Mar 26, 2003 | 08:38 PM
Dave19yz28's Avatar
the one at pepboys or autozone may not be for the LT1. The LT1 Thermo is different than the other small block chevy t-stats. You're better off just going with the hypertech...plus they're only like 20 bucks.
Old Mar 26, 2003 | 08:41 PM
norcalstreet's Avatar
Make sure both are for the LT1 since the LT1 uses a special reverse coolant flow. I have heard of people getting a 160 degree themostat from AutoZone for about $8. There's no difference in quality. Just price.
Get the cheapest one.
Old Mar 26, 2003 | 08:54 PM
chesee48's Avatar
Dont forget, you need something to tell the fans to turn on, otherwise the 160 tstat is pointless.
I.E: Hyper-crap, jet or slp fan switch, or custom programming ( www.madz28.com or www.pcmforless.com )
Old Mar 26, 2003 | 09:10 PM
I don't agree with that statement, but you want the long thermostat that is made to work with your reverse flow system.
Old Mar 26, 2003 | 09:23 PM
Fbody1's Avatar
ok I have the regular small block thermostat(160) have reset the fans for this , but the car never seems to get hot , or eaven warm, I'm in FL so winter is not very cold , I have to block off 80% of the radiator to get it warm (170 to 180) , but in the summer it stays @ 160 or below most of the time , some times when a little cool outside it takes 10 to 15 min of driving to go to closed loop , I think I will try the other t/stat , any suggestions
Old Mar 26, 2003 | 09:52 PM
94F1Z28's Avatar
Well from what i understand the thermostat for the LT1 is what they call a 2 way thermostat.It mixes cool water from the rad with hot water from the block.I would recommend you get the proper thermostat.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
