Complete engine rebuild parts list
Am I missing anything?
crankshaft
connecting rods w/ bearings
pistons
piston rings
all gaskets
cam
lifter
spring w/ seats, shims, locks and retainers
freeze plugs
pushrods
1.6 rr's
crankshaft
pistons
piston rings
all gaskets
cam
lifter
freeze plugs
pushrods
1.6 rr's
Timing set, and the way you said "connecting rods w/bearings" makes it seem like you mean rod bearings only. If that's the case, you need to add cam bearings and main bearings to your list. Other than that, I believe you have all of the parts under control. Now it's just figuring out what brand and type of those parts you want.
Yup...thats gonna be the hard part. I thought main bearings were the bearing around the big end of the rod, but I guess not. I am still trying to learn more. I want a stock bottom end, but a medium size cam, I would like to have around 350hp. I also plan on getting the heads ported.
main bearings are what the crank spins on
rod bearings are what the rod spins on
cam bearings are what the cam spins on
you might want to include a water pump, valve seals, rear main seal (a gasket in effect) oil pump, oil pump drive, pickup, injectors, new head.intake.main bolts amongst other various bolts.
Lots of fluids, beer and patience
Brandon Wittmer
Dec 20, 2014 09:51 PM
