ODBI Big Convertor shifting problems
Old Mar 26, 2003 | 03:15 PM
468ss's Avatar
Does anyone have a LT1 Edit file to fix the big stall convertor problem. Or does anyone know of a way around this problem for sure?
Any help would be appreciated.
Dennis
Old Mar 26, 2003 | 05:01 PM
brokenz's Avatar
If you want I can send you a copy of my current flash from work tommorrow with a list of what was done to it. It seems that some people can get around this by changes in the flash and some can't.
Old Mar 26, 2003 | 05:38 PM
Twice The Fun's Avatar
what does it feel like when this happens, what does the car do....im wondering if my 3000 stall is causing some of my tranny probs
Old Mar 26, 2003 | 10:07 PM
AHARTZ28's Avatar
email brian at pcms for less he has a fix it fixed mine
Old Mar 27, 2003 | 11:46 AM
468ss's Avatar
You would definetly know if you had the problem. It is caused by a stuck bit VSS error (due to the nature of large convertor + slippage+ quick acceleration). the symptom is a soft 1 - 3rd shift on hard acceleration. the tranny will skip 2nd gear completely. this is due to the trans operating in backup (limp) mode due to the VSS error.
Brokenz
were you experiencing this problem, and by the changes you made, did this fix the problem?
Dennis
Old Mar 27, 2003 | 01:19 PM
is it possible that this could cause the tranny to slip into different gears while driving, mine will do okay for a while, but then it will jump around in gears, like 4th to 3rd, and back to 4th, frequently, while im cruising.
does it happen at part throttle is what im trying to say
Old Mar 27, 2003 | 02:41 PM
brokenz's Avatar
Originally posted by 468ss
Brokenz
Dennis
Basically the motor would hang on the rev-limiter before the1-2 shift. All I did is lower the mph until it shifted where I wanted and increase the line pressure across the board to make up for the softer shifting all the time with the high stall.
Old Mar 27, 2003 | 05:23 PM
Dan K's Avatar
No. It shouldn't.
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
