What coil are you guys using?
Old Mar 26, 2003 | 10:21 AM
93zder's Avatar
Wondering if i should stick with the stock or go aftermarket if there are gains to be had.
Also, how long should the stock one last?
Old Mar 26, 2003 | 10:29 AM
hairbear21's Avatar
You probably won't see any gains from an aftermarket coil on a relatively stock engine other than a smoother idle-if that. I put on an MSD coil and it make no difference whatsoever, but if I was running N2O or a supercharger, then yes I would run an aftermarket coil with an ignition control box.
Old Mar 26, 2003 | 10:39 AM
jkipp84's Avatar
I've had an Autozone OEM equiv type coil ($19) for several years now. No problems.
Old Mar 26, 2003 | 10:56 AM
96cam4ro's Avatar
Smile
I got increased fuel mileage..
17 mpg - noticed there was something wrong..
19.5 mpg - replaced the locking gas cap with an original GM one..got back the power and gas mileage
21 mpg - replaced the stock coil with an MSD blaster coil
20.2 mpg - changed to 3.42's
23.6 mpg - cleaned out my air filter that had been down there for 9 months..bloody muddy if you asked me..
This is with the mods below...
Old Mar 26, 2003 | 12:05 PM
93zder's Avatar
I will be doing my plugs and wires very soon so i thought it may be worth it to swap the coil while i was in there if there were gains to be had. Hmmmm ...
Old Mar 27, 2003 | 12:38 AM
TLyden316's Avatar
Did changing the gas cap really make a difference? I have a locking one as well and maybe I should get rid of it.
Old Mar 27, 2003 | 12:56 AM
Fatdog's Avatar
Cool
Stock.My02
Old Mar 27, 2003 | 07:45 AM
hairbear21's Avatar
I have heard that locking gas caps will cause problems because they are more or less a generic deal, and they do not hold the pressure, and that will make a difference.
Old Mar 27, 2003 | 08:18 AM
teke184's Avatar
at $40 from summit my view is that it can't hurt...
Sergio
Jan 27, 2016 04:27 PM
maybe2fast
Feb 5, 2015 05:14 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Red97LT1
Aug 7, 2002 05:45 PM
