Need some advice
Old Mar 25, 2003 | 11:20 PM
5H9D0W's Avatar
Need some advice
My driver side header is leaking air,and I have to get rid of that damned ticking.What kind of header gasket should I get.The standard fel-pro or an alumminum or copper gasket.I don't want to do this again.
Old Mar 25, 2003 | 11:47 PM
5H9D0W's Avatar
I'm buying and installing it tomorrow. TTT
Old Mar 26, 2003 | 12:05 AM
Wild1's Avatar
I've got the fel-pros... no leaks since 95. I soaked them for a few hours and bolted them on. After each of the hot/cold cycles I tightened the bolts (5 cycles).
Old Mar 26, 2003 | 12:13 AM
5H9D0W's Avatar
I don't think I understand
Old Mar 26, 2003 | 12:21 AM
Wild1's Avatar
Soaking the exhaust gaskets is supposed to soften them, when you clamp them in they shrink and get really tight. It is supposed to make a great seal. I can't complain as I did this method and they still work since 1995.
Also, when you start the car it gets hot. The heat affects the gaskets. When it cools it contracts... re-tighten the header bolts after a few heat cycles. This will ensure a good, tight seal.
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
