Need a quick part number
Old Mar 25, 2003 | 10:04 PM
ltlhomer's Avatar
I am in the middle of heads/cam swap and I need two of the plugs that go into the front of the heads in order to block off the coolant passages since the lt1 heads have coolant holes drilled in both ends but they only use one set for the x-over pipe in the back. All I need is a p/n so I can get this show on the road. Thanks for you help.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
