For those who have the BMR Adjustble torque arm.....
Old Mar 25, 2003 | 08:58 PM
WipeOutXXL's Avatar
Another one of those how-to question's....I had the Adjustable torque arm installed, I feel a little bit of a difference with the car's rear end being a little more stable but is there any efficient way to adjust it....?...I was looking at the boltage and I don't know what's too tight or too loose....thanks for the info..
Later,
Chris
Old Mar 25, 2003 | 10:49 PM
sleeperZragtop's Avatar
Hey man, torque the front bolts at the tranny to 37 foot pounds and the axle bolts to 40 foot pounds...that will be fine...as for the right angle you'll need to get an angle finder and get the right degree...if you don't have an angle finder call BMR and get the best specs for your car...A4 or M6...they will be different. Ask for the thread count or how many threads in mm on the thread bolt on your torque arm for the best angle...you know what I mean..good luck
Old Mar 26, 2003 | 01:58 AM
If you can understand this..it may be helpful...
pinion angles
..hope this helps
football4life
Oct 4, 2015 07:48 AM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
