What can cause high rpm misses
Old Mar 25, 2003 | 07:00 PM
Indy93Z28's Avatar
I want to know what can cause this besides the opti.
Old Mar 25, 2003 | 07:32 PM
Coil, ignition control module, spark plug wires, probably some more stuff.
Old Mar 25, 2003 | 07:54 PM
Indy93Z28's Avatar
Am I just going to have to change out a bunch of stuff and see what works then?
Old Mar 25, 2003 | 08:01 PM
Tofer's Avatar
If you are gonna go that route, start with the plugs and wires first. How long has it been since they have been changed. If it has been a long time, it wouldn't hurt to change them anyway. It fixed my car when it had the same problem. Good luck
-Chris
p.s. you comming on the 12th?
Old Mar 25, 2003 | 08:04 PM
LS1_03's Avatar
Plugs and wires would be my first thing to change if I were you.
Old Mar 25, 2003 | 08:06 PM
Indy93Z28's Avatar
Aren't plugs and wire expensive to have done?
Old Mar 25, 2003 | 09:11 PM
TMDZ28's Avatar
i dont think so as long as you do it yourself
Old Mar 25, 2003 | 09:14 PM
Indy93Z28's Avatar
Well I just spent around $800 changing the water pump and opti so money is tight and I'm buying new tires. I was hoping I could get an answer that would narrow my search to the definite prob, but I guess these cars are too complicated for that
Old Mar 25, 2003 | 10:17 PM
ibanezgod's Avatar
I'm having similar problems... and i believe its due to my lack of getting a tune up and my car now has 103K on it. My RPMs jump around like a crackhead on a trampoline... i'm changing everything including the stupid #%@#$@!#$ overpriced OPTI ......
Old Mar 25, 2003 | 11:47 PM
Indy93Z28's Avatar
I think I'll start with the fuel filter and go from there. As far as I know it probably hasn't been changed in a while.
Old Mar 26, 2003 | 12:48 AM
RedZ-28's Avatar
Maybe your tranney is slipping
Old Mar 26, 2003 | 01:26 AM
Fatdog's Avatar
Cool
Might do the coil wire first.I have to change mine every 6 months ,to a year or so.It's very simple,but use the die-electric greese on the coil terminals to.This sounds too simple I know,but if you are going to do the wires anyway,it comes in the pack.Do this first.Hope this helps.
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
