What can cause high rpm misses
Originally posted by Indy93Z28
Am I just going to have to change out a bunch of stuff and see what works then?
-Chris
p.s. you comming on the 12th?
Well I just spent around $800 changing the water pump and opti so money is tight and I'm buying new tires. I was hoping I could get an answer that would narrow my search to the definite prob, but I guess these cars are too complicated for that
I'm having similar problems... and i believe its due to my lack of getting a tune up and my car now has 103K on it. My RPMs jump around like a crackhead on a trampoline... i'm changing everything including the stupid #%@#$@!#$ overpriced OPTI ......
Might do the coil wire first.I have to change mine every 6 months ,to a year or so.It's very simple,but use the die-electric greese on the coil terminals to.This sounds too simple I know,but if you are going to do the wires anyway,it comes in the pack.Do this first.Hope this helps.
sleeperZ96BT
Jun 5, 2005 09:33 PM
