Could someone look at my Datamaster files?
Old Mar 25, 2003 | 05:50 PM
rickyzZ28's Avatar
It is for a 93 Z28. If you could post your emails I will send you the file. What i am looking for is your opinion of how the car is running now. The car will not idle, runs extremely rich, the O2's wont cycle. If I let off the gas the car will spit and sputter then die. If I try and keep it running it knock and pings. It seems to have a slight miss as well. I can find no vaccum leaks and the opti, wire, plugs, MAP, IAC, IAT, are all new. Have tried a different coil and ICM and it made no difference. Thanks
Old Mar 25, 2003 | 11:00 PM
I'll take a look at them, but only if you can send them as ".csv" files (there is an option in DataMaster to "export as......".
e-mail is visible.
Old Mar 26, 2003 | 12:44 PM
rickyzZ28's Avatar
Sweet I will send them to you tonight. thanks
Old Mar 26, 2003 | 12:59 PM
96ZRDR's Avatar
Please send them to me too. I have pretty much the same set-up and problem. I want to compare.
Email: joe.gonzalez@trw.com
Old Mar 26, 2003 | 01:03 PM
96ZRDR's Avatar
BTW, are you still using the stock 22# injectors?
Old Mar 26, 2003 | 01:13 PM
rickyzZ28's Avatar
I had 24# injectors in the car and then we changed them back to the 22#, becuase of the the extremely rich problem. Programing was changed as well.
Old Mar 28, 2003 | 02:45 PM
rickyzZ28's Avatar
e-mail is visible.
I have been trying to email you but I keep getting an error message. It says that your address has fatal errors and can not be sent.
Old Mar 28, 2003 | 03:01 PM
Not the first time I've heard of people having problems with my e-mail, but most people are able to reach me at:
InjuneerZZ@aol.com
But then they don't call it "AO(HEL)L" for nothing.
I do have a lot of e-mail IPS's "blocked" because they don't make any effort to limit SPAM... if you are using one of the ISP's that doesn't control SPAM, you aren't going to be able to e-mail me.
EDIT: You use "hotmail.com" and I'm pretty sure I have it "blocked"..... I will "unblock" it tonight after 7:00PM eastern time. Try sending it then.
Fred
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
tommalcolm
Sep 11, 2015 03:39 PM
