Questions about Clutchs
Old Mar 25, 2003 | 02:36 PM
jeff94z28's Avatar
Ill make it quick and short. If you want to hear the story you can really ask but I dont feel like writting it out now.
The shop my trannys getting rebuilt at uses Luk Clutchs. I asked if they would do a centerforce or some other brand I have heard of but they wouldnt give me a warranty so I said forget it.
But I was told BY HIM that they hold better then stock but I dont trust a thing he tells me. I want to hear from the boards and the people that have used a LUK clutch or know about the company quality in general.
Can any of you give me any insite on it. Hows it hold compared to o.e.m., how good they are etc.
Thanks.
Old Mar 25, 2003 | 02:47 PM
norcalstreet's Avatar
Almost all clutches hold better than stock. Centerforce is better for Mustangs than it is for Camaros. If you want a clutch slightly better than stock get a Stage 2 Star Spec. If you want to go all out get a McLeod Street Twin but for a fairly stock car it is major overkill. For something which isn't much higher than stock get an LT4 clutch.
Never heard of Luk Clutch's.
Old Mar 25, 2003 | 02:48 PM
jeff94z28's Avatar
Well thats a start and good to hear.
Old Mar 25, 2003 | 04:02 PM
jeff94z28's Avatar
Just bring it back up.
Old Mar 26, 2003 | 08:21 AM
IDOXLR8's Avatar
In my opinion I would not go with a Centerforce clutch. What kind of budget are you working with?? If you plan on doing big mods in the future then I suggest doing it right the first time and going with a McLeod Street Twin. If not I would recommend going with a RPS clutch.
Old Mar 26, 2003 | 09:26 AM
PatriotTA's Avatar
Centerforce is nothing more than re-worked and re-painted aftermarket clutches. I think in the F-car case, the Centerforce cover is the LuK cover painted orange with weights hung on it to increase clamp load. I work in the clutch business, and LuK has a good aftermarket program going, although I haven't seen firsthand their F-car setup. I have heard a lot of bad things about Centerforce, so I wouldn't go that route. If you wanted to keep it cheap, you could go with LuK, but also look at McLeod and SPEC. McLeod has a performance single disc setup that is about $400 compared to the $900+ for a street twin.
Old Mar 26, 2003 | 03:28 PM
jeff94z28's Avatar
Well the Luk Clutch is what I told them to put in partly because I cant stand to not have my car any longer. Its been over a week so I didnt want to wait another for them to have to get a different aftermarket company shipped in.
So basically I was just looking to hear from people what they thought about Luk quility and how well it would hold compared to my stock one.
Thanks PatriotTA for the help. Its nice to know Luk has a little bit of a name out there. I had just never heard of them so I had to ask.
Old Mar 26, 2003 | 04:44 PM
PatriotTA's Avatar
Originally posted by jeff94z28
[B}Thanks PatriotTA for the help. Its nice to know Luk has a little bit of a name out there. I had just never heard of them so I had to ask. [/B]
The reason you've never heard of them is the fact that they are not a performance company. We've all heard of Centerforce and SPEC, etc. but companies like LuK and Sachs are mainly OE companies, but the both have really good aftermarket programs going. The stock clutch set for your car should be made by Valeo, which isn't very good, the LuK is a nice step up from stock, but its not going to hold 400 horsepower or anything.
Old Mar 26, 2003 | 04:46 PM
How much is he charging for the Luk clutch?
Old Mar 26, 2003 | 09:28 PM
jeff94z28's Avatar
The Luk clutch is 700 bucks. And Im not planning on pushing any huge numbers. Not anytime soon atleast.
Old Mar 27, 2003 | 06:48 AM
QUASARBLUEZ28's Avatar
I hope 700 $$$ includes the install. Luk's run less tha 300.00 $.
They are a very good stock type replacement .
One of my co workers in Ohio has a brother that works for LUK.
He even gets free proto types to test.
Old Mar 27, 2003 | 07:12 AM
jeff94z28's Avatar
Yea that is installed.
Old Mar 27, 2003 | 08:17 AM
Super Slow '97's Avatar
I have a Luk clutch and hate it it does not stand up to the abuse of the strip. It holds fine around town but once you get some heat built up in it at the track it will slip. I would go with the spec. JMHO I have been through two Luk's first one we thought was faulty b/c it was slipping when it was new so we put the next one in sdame thing. I broke it in for about 400 miles and had the flywheel turned so the install was done right. Any way stay away if you can.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
