What to use to remove crank hub??
Old Mar 25, 2003 | 09:31 AM
jpolz's Avatar
Autozone doesn't carry a "hub puller" specifically....what can I use to remove it? Will a generic 3-toe puller work instead?
Old Mar 25, 2003 | 11:23 AM
jpolz's Avatar
Exclamation
TTT
Old Mar 25, 2003 | 11:41 AM
GREGG 97Z's Avatar
I got the least expensive on Sears had for $19.99, it came with an assortment of bolts to use. It was called a hub or balancer puller, it worked fine.
Old Mar 25, 2003 | 11:51 AM
A traditional "harmonic balancer puller" will work. However, most have a large shaft and you will have to put something inside the crank threads to protrude out, so the puller shaft will not push against the hub. You have to do this because the hole in the hub is small. Whatever you use, don't let it get stuck the crank thread hole.
Old Mar 25, 2003 | 11:59 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I just pulled it off with a hub puller my friend had. It worked fine. Couldnt have done it without it. It was really on there when i removed it.
Chris
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
