Improvements with a 4000 stall on a 12.5 car
Old Mar 24, 2003 | 09:56 PM
z2894convertible's Avatar
Question Improvements with a 4000 stall on a 12.5 car
What kind of times and mph improvement do you think I will get with a 4000 stall?
Old Mar 24, 2003 | 10:09 PM
Smokn '94 Z's Avatar
Lightbulb
It depends on where the peak HP is on your car. It could hurt. Depends on mods.
Old Mar 24, 2003 | 10:26 PM
I have hotcam kit, ported heads, coated Hooker LT`s, ORY, crank underdrive pulley, cai, air foil, borla exhaust, !EGR, !AIR, and custom tuneing.
Old Mar 24, 2003 | 10:32 PM
Question
No stall at all yet? If so then you will definately see a great increase but maybe a bit overdone for the Hot Cam. I ran a 12.9 with my Hot Cam on a stock stall then I went to a 3200 vig & ran 12.3's all day. It is probably the most optimal stall for the Hot Cams HP range. However for the never ending quest of trying to get everybit of et I can I am, as we speak getting my stall re-stalled to 3600 along with the FLP Level 4 trans. I am hoping It don't cause me to lose a bit of ET. It very well could, but I have to try...
Old Mar 24, 2003 | 11:01 PM
My stall is still stock. What were your mph on a stock stall? The hotcam puts out power well over the 4000 rpm. 4000 and above is where it is at its best. How did you get your OBD1 to run with a stall over 3000. I am going with a 700r4.
Old Mar 24, 2003 | 11:04 PM
Arrow
My best trap speed was 106 before the stall. Now it is usually between 108 & 110. As far as the OBD1 issues, I did have them. But Bryan at www.pcmforless.com has the fix. It worked like a charm. Now I won't have to worry about it ever with the FLP Level 4 trans.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
92ragtop
Dec 27, 2014 01:56 PM
USAirman93
Nov 24, 2014 03:37 PM
