Need some good looking valve covers to clear a studgirdle
Old Mar 24, 2003 | 06:06 PM
Acct 23749's Avatar
Did a search and found one post that wasn't very helpful
I am going to be running a moroso 67040 (or 67045) centerbolt heads stud girdle and I will obviously need some new tall valve covers... ANy ideas?
I would love these ones from summit (part #440336) http://store.summitracing.com/partdetail.asp?part=34796 but summit is "not sure if the will clear a stud girdle"
And will clearing the alternator i have a guy who can notch it no problem...
Anyone running these?
What is everyone with stud girdles running? std bolt heads?
The only other ones i have seen are what my friend has these... http://www.melroset-tops.com/race.htm#The%20 but they are very unattractive and very heavy
any help would be great
Old Mar 24, 2003 | 06:27 PM
Mindgame's Avatar
Go here: http://www.flatlanderracing.com/index.html
When you get there scroll down to Valve Covers, then go to B&B, then to Centerbolt.
You'll see that B&B makes a valve cover that's 5/16" taller than stock.... they even designate some of them as "for use with stud girdles"... they also build any of those valve covers listed with the alternator clearance built in.
Good luck.
-Mindgame
Old Mar 25, 2003 | 11:17 AM
Acct 23749's Avatar
Cool thanks, i will look into those...5/16 more then stock is all the clearance you need to run a stud girdle??
Old Mar 25, 2003 | 05:16 PM
Mindgame's Avatar
Considering the fact that they are listed in this way:
SB Chevy '87-Present; for stud girdle (sgl)
'87-Present; center bolt for for stud girdle, Polished, No Holes (pr)
I think it's fair to assume that the covers for use with stud girdles are maybe a bit taller.
With old school small blocks I've never really thought much about it because any cover designated as a "tall".... is always plenty tall for clearing girdles. 5/16 isn't alot though so I'd expect a bit more height in those specified to clear girdles. Give Flatlander or B&B a call to find out for sure.
-Mindgame
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
